Prius flooding ?
Discussion in 'Gen 2 Prius Main Forum' started by Vanne, Aug 12, 2012.
  1. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    I just want to know that if we have a heavy flooding what should we do with the prius car and if accidentally drive on flooding what happen to the system of the car ? thank you for advice
  2. Patrick Wong
    18,210
    6,526
    If the Prius is caught in a flood where water can enter the passenger cabin, that will cause significant damage:
    1) The navigation system and audio amplifier units are located on the cabin floor under the front seats, so those units will definitely require replacement.
    2) Residual moisture from the flooding will damage the wiring harness behind the instrument panel. Many ECUs are located there. You can expect intermittent connections which will be almost impossible to identify and repair.
    If flooding is a reality in your locale, then buy the simplest, cheapest car you can find. That car is likely to be much easier to repair - or at least, you'll have less of a financial loss if the car cannot be repaired.
