Prius For a Driving School Car?
Discussion in 'Gen 2 Prius Main Forum' started by hep1966, Apr 4, 2012.
  1. hep1966
    hep1966 Junior Member
    28
    PA
    I bought a Certified 07 with 70k miles. No money down and 2.9% financing.
    I noticed (under the factory brake pedal) that there are 2 bolts with threads extending up into the cabin. There are nuts holding something in place but there's still enough thread exposed to get another nut on top. I might be able to attach my pulley base there.
  2. Patrick Wong
    18,210
    6,517
    Congratulations on your decision. I would have counted myself among the group who is not sure that the Prius is the best car to learn on, for students who will not be driving that vehicle subsequent to lessons. Nevertheless I am sure your students will have positive experiences with it.
    My daughter learned how to drive using our 2004 Prius and is now the primary driver of that car.
    Speaking of unwieldy vehicles to learn driving on - in 1969, I learned how to drive on a Plymouth Satellite with absolutely no power accessories and three-speed manual transmission, column mounted. For those who can recall the size and bulkiness of that vehicle, it was not easy to learn on but made every other car that I have driven easy-to-drive. My driving instructor even fell asleep at one point while I was driving, so I suppose my student driving techinique was sufficiently relaxing for passengers.
    2 people like this.
  3. macmaster05
    macmaster05 Senor Member
    4,050
    730
    This guy spits gold everybody. Sometimes I don't even have to read what Patrick writes and I know it's gold.
  4. hep1966
    28
    PA
    Put a couple hundred miles on the car and guess what......? It drives like............. a car.
    I've driven old Chevrolets, new Audi A8s and a lot of other cars and I don't understand why anyone would think that a Prius is difficult to drive. You don't feel the shift points because there are none. A pillars are a problem in almost any car. I don't think that they're any better or worse in the Prius. I peek over my shoulder for a lane change and can see through the rear door window. The "bar" across the back window is the only thing that's taking some getting used to.
    I don't understand any of the negative comments about teaching someone how to drive in a car that they won't be using for a test or for their daily driver. Can you imagine how many cars I would have to buy in order to teach someone how to drive their specific car?
    I hope to transition my lessons from the Cavalier to the Prius within the next week. I'll take pictures of the installation of the brake setup.
  5. CookieGuru
    CookieGuru Member
    104
    Seattle
    2013 Prius Plug-in
    Hey hep--how many hours is your driving course and how many hours do drivers need to have under their belt before getting their license?
  6. macmaster05
    4,050
    730
    Didn't I say this a few days ago? :) Best wishes to
    you.
  7. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    That would be wonderful. Please continue to post them in this thread, as it would then capture all of the issues (pros, cons, installation, etc) in a nutshell.
  8. Patrick Wong
    18,210
    6,517
    I'm very interested in seeing how the auxiliary brake pedal will work.
    I don't expect that a driving school must offer a vehicle that is highly similar to that which the student eventually will drive. I believe that relatively inexpensive and small vehicles are frequently selected for this purpose. Such vehicles have simple controls, a simple body design, offer reasonable visibility and are usually fairly easy to drive.
    I had a few reasons in mind when suggesting that the Prius might not be the ideal driving school car:
    1. A-pillar and rear spoiler visibility impairment, as previously discussed
    2. An electronic shift control that is fairly unusual, with a separate P button and a game-control style shifter on the dashboard for other gear ranges
    3. The MFD and rear camera display can potentially be distracting
    4. The gasoline engine usually turns off when the car is stopped. That can seem very weird to some people.
    5. If the car should have an accident, repair costs typically will be higher than with other vehicles of similar size that might be used for driving school due to the hybrid-specific components
    In any event you'll quickly build up your personal experience with the car and will decide if there are any Prius-specific issues associated with driver education or not. Good luck!
  9. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    One thing that might keep things interesting for the kids: when you are letting the student do a long drive, reset the fuel consumption on the MFD, then turn it off. At the end of the drive, turn it back on so the student can see their MPG.
    I agree with others that the MFD can be distracting -- have you thought about whether you will leave it on or turn it off in general?
    I also did not see anyone mention the overly restrictive traction control. When starting out on snow/ice, you may find a situation where the car does not move due to wheel slippage. It is not possible to make the front wheels spin in order to "rock" your way out. I suppose the kids can jump out and suffer the humiliation of pushing a Prius, but it is highly recommended to run good snow tires in winter if you get that sort of weather.
  10. hep1966
    28
    PA
    The driving course in Pennsylvania is 6 hours behind the wheel and 30 hours in a classroom or online. I run an online course and do the behind the wheel lessons.
    A driver under 18 is supposed to have 65 hours of practice before taking the driving test.
  11. hep1966
    28
    PA
    After looking at the car, I’ve come up with an idea that would require no drilling, cutting or welding on the Prius chassis. I may have to trim some carpet and or kick panels.
    If you look at the pictures below you will see a series of threaded studs sticking out from the floor/firewall area. It seems that 2 on the driver side hold a small cable and 2 others are used to hold the plastic cover for the steering column. On the passenger side there are 3 studs, one helps hold the kick panel in place and the other 2 are supporting something unknown to me.
    My plan is to use these studs and some nuts to mount custom brackets to attach my auxiliary brake.
    I do not have any service or repair manuals yet but I do plan on buying some soon. What is the cable on the driver side? What are the studs supporting on the passenger side?
  12. CookieGuru
    CookieGuru Member
    104
    Seattle
    2013 Prius Plug-in
    59 hours that have to be in another car... not sure why other posters were freaking out about them "learning" in a car other than what they'll test in.
    Search the forums first; there's some good info you'll find in a thread that links to another site.
  13. hep1966
    28
    PA
    We’re almost done with the installation. We need to get a longer housing for the cable. Here are a couple pictures. No drilling, cutting or welding was done on the chassis.
  14. ataylorracing
    ataylorracing ataylorracing
    171
    29
    Fishers, IN
    I would not think the Prius would be a good drivers car since nearly 100% might freak out when the motor cut off, having never experienced it in their lives. They'd get used to it, but also, since most cars have a shifter marked as D, R, P...another difference between cars they would be using at home compared to the drivers ed car. For real world experience they should be forced to learn on HUGE sized cars so they could be taught to judge clearances better....making smaller cars easier to drive after schools out.
  15. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    Looks good!
    Many arguments could be made for how to teach driving, i.e. stick shift, big car, etc., but in 10 years every new car will be some kind of hybrid or EV. Might as well learn 'em young, just sayin...
  16. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    'Freak out'? Don't be ridiculous. People get used to it about the second time it happens. After that, anytime they're sitting in an old fashioned car, they say 'What? The engine just keeps running, even when the car's not moving? That's crazy.' :)
    2 people like this.
  17. CookieGuru
    CookieGuru Member
    104
    Seattle
    2013 Prius Plug-in
    So does the Prius:
    The only difference is that P is a button above. Otherwise it's the same order: P, R, N, D top to bottom.
  18. Tideland Prius
    16,680
    But if you're 16, it wouldn't matter. They just have to be taught that it's ok in a hybrid but not ok in a regular car!
