Prius Four or Five? Pre-collision worth it?
Discussion in 'Gen 3 Prius Main Forum' started by sneagle, Feb 23, 2012.
  1. sneagle
    sneagle New Member
    NYC Metro area
    We left to research and talk more.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Sounds like a good decision.
  3. hp2009
    hp2009 New Member
    usa
    i would not fall in all that,
    how many car you will see on dealer lot with all those (eg. radar cruise control, Pre-collision system and lane assist. ..)..only one or two....why ...people do not buy those expensive car.....final word....it is prius....more saving ,,,if u buy low end model....
    ....it's all about spending more money from you....
    you can buy high end car for that price
    thanks
    hp
  4. tommygun
    tommygun Who was that masked man?
    35
    New York City
    I agree completely regarding DCC. Not to belabor my point on LKA, but I just find that too much "beeping" when the car senses false danger is distracting. I prefer to be able to turn the feature off and have it stay off until I turn it back on. For you folks who know:
    1) Does LKA come on whenever the car is started?
    2) Does it come on automatically when DCC is activated?
    3) Can I use DCC without KTA?
    2) Can I turn it off while driving and have it stay off?
    3) Can I change the default setting so it's off unless I turn it on?
    4) None of the above?
    I am soon to pull the trigger and the online version of the owner's manual is not clear on this. Thanks.
  5. sneagle
    sneagle New Member
    NYC Metro area
    Ok. I think my wife and I have agreed to a 2012 Four with the solar/NAV package.
    What is a reasonable price? Sticker is $32,815. Invoice is $30,462.
  6. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    You must actively turn DRCC and/or LKA on if you want to use them; they are independent systems. Both DRCC and LKA are off by default when you start the car. PCS is always on in equipped Prii, although there is a switch under the dash that deactivates phase 3 (auto braking) if you don't want it. You won't even know that a properly working PCS is there, unless the system senses an eminent front end crash or you slam on the brakes at 55+ MPH (front seatbelts retract).
  7. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    There shouldn't be too much false danger unless you're careless in keeping the car in the center of the lane, and LKA temporarily turns off when you change lanes (with the turn signals on). In other words, it still requires your full attention.
  8. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    Two points:
    1. The Pre-Collision system only works when the DRCC is engaged (at least on the 2011). This was an incorrect statement (and is grayed out)
    2. The model Fives' 17" wheels will (according to other threads here) get around 3mpg poorer mileage (despite what the EPA sticker says).
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Bullet 1 is wrong, the Pre-Collision system is always active. I'm not sure about "at least not on the 2011", I can't see them making a safety system which is only on when using the cruise. Was this stated in Toyota literature?
  10. dhancock
    357
    40
    As I recall. However, I am out of town and can't re-check the manual. What does your (2012) manual say? I thought that it might be an important point as the OP was looking for the added safety margin for his teen age son.
  11. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    Correct.
  12. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    My 2012 is not here yet, I'm getting the PiP, should be here in a little over a week.
    That said, there is no way the PCS only functions when the radar cruise is set, that's simply not a change they would make from 2010 to 2011 and on. The PCS is an always on safety system. I'd correct that bullet point as to not confuse people when you can.
  13. Econ
    Econ Member
    329
    26
    East of the Berkshires - MA
    Get it! It saved me once. I do not drive with out it on. You perhaps can get the dealer down on that price.... maybe $1,500.00
  14. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Correct and the Intelligent Parking Assist sensors are always on as well, which is how you can skip the slow pre-support system and it'll still detect the parking spot for faster self-parking.
  15. sneagle
    sneagle New Member
    NYC Metro area
    I could not convince my wife to spend the extra for a Five There was a dealer Prius that was a five (with 6,000 miles) but it was a 2011 and no sunroof. So we got a four.
    Just drove off the lot.
  16. sneagle
    sneagle New Member
    NYC Metro area
    Thanks got all the help!
  17. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Congrats! The sunroof was not available on the five even if you wanted it. I'm sure you'll be very happy as will the wife.
  18. dhancock
    357
    40
    I looked up the manual on-line and it sort of implies that the PCS is always on (unless intentially turned off or radar sensor inoperable - as when covered with ice*). This feature only makes itself evident under rare circumstances, so it is easy for my wrong assumption to continue. My previous post will be corrected.
    *ICE: I've lately run into several instances where the DCC stopped (and I assume the PRC also stopped) due to ice covering the sensor. You'd think that with heated seats, rear view mirrors, headlight washers that they would have a radar sensor deicer! :rolleyes:
  19. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    I have received a warning that says something like 'radar sensor needs cleaning' when using DRCC in light rain where dirty water is splashed up by other cars. I don't know for certain, but think this results from water and dirt on the Toyota emblem, right in front of the radar unit. Perhaps my water problem and your ice issue is the emblem, rather than the radar unit.
  20. dhancock
    357
    40
    The obstruction is on the emblem, but that is effectively the cover for the radar sensor. Most of the time this occurs it has been ice forming, but I have had one instance where it was water - perhaps water close to freezing. It is a pain when this occurs - particularly when driving interstates, where opportunities to clear it are limited. I also noted one instance where the cloud of water thrown up by the car I was tracking obscured the car ahead (turned it into a stealth car). Goes to show that one shouldn't rely on either DRCC or PCS.:eek:
