Prius G2 2010 started to reduce engine oil
Discussion in 'Gen 2 Prius Technical Discussion' started by abuzer, Jun 28, 2018.
  1. abuzer
    abuzer New Member
    Lahore
    I am very new to this forum.
    I am trying to figure out the issue of the engine oil reducing for my car. I have been changing it on 3000KM. But some how for the last engine oild change it was 0.75 litter reduced.
    I have tested in cold environment, it throws white smoke (steam)
    What can be the possible causes and cures?
  2. abuzer
    abuzer New Member
    Lahore
    Can this be cause of PCV value?
    52,898
    how many kms on her? are you sure it is not gen3?
    ITBland and Mendel Leisk like this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    2010 is a G3 car.
    White steam out of exhaust is blown head gasket. Lots of reports of that over in the G3 forum. Go over to that forum and read up on that.
    ITBland likes this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Come on Ed.....really.....NOT.
    Some white steam when started cold is NORMAL and is due to condensation of the moisture in the hot exhaust gasses.
    A LOT of white steam that never really goes away completely likely would be a head gasket.
    OR it really is white smoke, caused by increased oil usage due to normal wear........IF the engine has high miles.
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    That's pretty often to be doing oil changes.
    Your car is about 8 years old. It the mileage is high, it might be "normal" wear and tear......but .75 liter in 3000 km is quite a bit.
    You probably need a mechanic to look for leaks and maybe do a compression test.
    "High mileage" thicker oil might help some.......but not if there are leaks.
  7. abuzer
    abuzer New Member
    Lahore
    The current milage is 160,000KM +
    There are no leaks for engine oils.
    I have checked the PCV valve is is clean.
    Using 20 50 oil
    This is the car i have (1500cc, 2010)
    What should be the compression test score?
    #7 abuzer, Jul 17, 2018
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    I have no idea.
    I think you need a "real" mechanic to look it over.
    Are you REALLY changing the oil every 3000 KM ?
    Or are you just adding oil every 3000 Km ??
    An experienced nose taking a sniff of the plume coming out of the tail pipe might tell you a LOT.
    If it smells like radiator coolant, then other tests would likely be a waste of time and money.
  9. bisco
    52,898
    2010 is gen2 in some parts of the world. or is 2009 gen3?(n)
    picture looks like gen2.
  10. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    I believe there was a limited edition or commemorative edition of the Gen 2 that continued into 2010 and was only sold in Japan.
    Something like that, but my memory of the details are a bit sketchy.
  11. abuzer
    abuzer New Member
    Lahore
    Yes i am changing the oil every 3000KM, not adding to fill to the.
    There is not any knocking or change in engine noise. it is smooth as it was before the oil issue.
    Yes, it is Japan edition. it was imported to my country in 2014
  12. MkImran
    MkImran Junior Member
    Pakistan
    .75 ltr after 3k km is normal
    I have same issue and search alot regarding this all I understand it's normal
    White smoke exist if all time then you need to replace assembly head do go for any repair
