Prius Gen 1 Issue (2003)
Discussion in 'Generation 1 Prius Discussion' started by KitsuneVoss, Feb 15, 2023.
Tags:
  1. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Congrats on the success.
    Now, while it's working is a good time to document what you learned. Unless you are going into the Prius repair business you may not ever need to do the same repair again. :) My Gen 1 worked properly for about 15 years and about 150,000 miles, then finally needed to have HV battery modules replaced.
    Bruce Berquist likes this.
  2. KitsuneVoss
    KitsuneVoss Member
    375
    55
    Virginia
    I have to accept that my Gen 2 (Gen 1 is my roommate's as I wrote previously) might need its battery replaced somewhere along the way as well. Not looked into how hard it is to replace the battery in a Gen 2.
    #62 KitsuneVoss, Mar 6, 2023
  3. Bruce Berquist
    Bruce Berquist Junior Member
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    I have also experienced the warning light with no codes. Take in mind that this warning light will also come on when it senses low oil, Low coolants and low brake fluid, and it will come on to "pending" trouble codes that many code readers don't read till the reading comes around as "temporary" or "permanent".
    When the triangle warning light comes on with the car symbol, it is important to pay attention to it. Stop and check all the safety and maintenance basics, oil, coolants, brake fluids, etc.. then it is OK to continue to a mechanic or to home, but that light always means that something needs service.
    My light comes on very rarely, but when it does, and I use a pro code reader, I find a pending code for my fuel tank vapor emissions which I haven't yet tracked down the actual cause. It effects one of the five readiness monitors for inspection, but in my state we pass inspection with no less than four monitors passing. I still intend to fix this when winter and mud season are over so I can work more deeply on the diagnosis.
    #63 Bruce Berquist, Mar 26, 2023
  4. Bruce Berquist
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    P.S.: The triangle light is not the "Triangle of Death", it is simply an important warning light. Don't Freak!
  5. Bruce Berquist
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    I won't mislead you and say that it is simple, but really it is not difficult to do, as long as to follow safety processes and procedures to avoid getting shocked or electrocuted, and get some instructions on access and removal and follow them.
