Prius Gen 3 GR Corolla Brakes conversion
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Matth Torrijos, May 13, 2026.
  1. Matth Torrijos
    Matth Torrijos Active Member
    121
    213
    Poway
    First Toyota GR Corolla brake swap on a Toyota Prius (ZVW30) Gen 3. thanks to 350PHI for the conversion kit and Hybridpit for install
    Parts
    350PHI Caliper Bracket
    350PHI Bolts
    350PHI Rotor Ring
    GR Corolla Calipers and Pads
    BRZ Brembo Rotor
    Optional: Stoptech Braided Brake line
    Installation: Bolt on Application, same procedure as replacing OEM Calipers with the exception of removing Brake Dust Shield due to inner clearance
    Removal of the brake dust shield is required since the hub needs to come off. You can cut the shield if you want, but I removed mine completely. I also couldn’t bend it back far enough because the issue isn’t the lip of the shield — it’s the backing plate of the brake shield making contact with the rotor.
    Joele3, w84me, Burna J and 1 other person like this.
  2. jacktheripper
    jacktheripper Senior Member
    284
    558
    OMG.... looks so good, I need it, calling Hybrid Pit now....
    Matth Torrijos and PriusCamper like this.
  3. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    Wow... Looks amazing. What would I expect to pay in parts if I did my own labor on a job like this?
  4. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
    Looks sexy...I like it
    Matth Torrijos likes this.
  5. Matth Torrijos
    121
    213
    Poway
    It depends on sale prices, it will be around 1k if you find some deals
    PriusCamper likes this.
  6. PriusCamper
    13,455
    5,430
    With a look that nice I'd probably need to buy some super clean new alloy mag wheels too...
  7. Quibble
    Quibble New Member
    Australia
    That’s an awesome swap! The GR Corolla calipers must be a huge upgrade for the Prius - bet the stopping power feels night and day compared to stock.
  8. Matth Torrijos
    121
    213
    Poway
    Yup it is, stopping definitely feels more premium, like your in control. Even on a daily drive it’s really enjoyable
  9. PriusCamper
    13,455
    5,430
    I agree it looks cool. But with regen braking and the light weight of a Prius this is the equivalent of using a giant sword instead of a steak knife to eat your dinner. It may look pretty cool, but there was nothing wrong with the normal steak knife in the first place.
    And don't just believe me, I showed this post to the guy in Oklahoma who builds high performance Gen3 Prius engines and his first reaction was how stupid he thought it was because a Prius doesn't ever get pushed to the type of limits that would require this type of braking system.
  10. Matth Torrijos
    121
    213
    Poway
    Who’s this guy in Oklahoma? Im interested on his performance gen 3 engine.
    And yeah overkill for a Prius? Yes
    Do you feel the performance difference and more controls braking? Yes (I was surprised too on this one)
    this is more on the quality of ride upgrade/improvements
  11. ChapmanF
    19,017
    My first guess would be the regen-to-friction transitions in moderate braking might feel a bit abrupt—you're slowing down at a rate determined by regen, the ECU goes to trade out the regen for what it's programmed to think is the corresponding brake fluid pressure, and your coffee spills.
  12. PriusCamper
    13,455
    5,430
    http://www.skimmilkhybrid.com/
