Prius Gen 3 HID Retrofit -- The Right Way. Lexus RX350 Bi-Xenon, German Osram, Denso
Discussion in 'Gen 3 Prius Accessories and Modifications' started by E46Prius, Aug 15, 2015.
  1. ilovegirls
    ilovegirls Member
    172
    40
    San Diego
    This is the easiest way for hid projectors retrofit.
    Greenteapri likes this.
  2. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    Thanks!
    What's a good bulb to pair with the RX projectors?
  3. ilovegirls
    ilovegirls Member
    172
    40
    San Diego
    I used pram cbi bulbs bought from the retrofit source.
  4. ksaepharn
    ksaepharn Junior Member
    San Leandro
    Damn. Haven’t been on here in a long while since so no one responded to my thread so never came back on here, lol. Check out my thread on rx350s. I’ve only used oem bulbs. Philips White Vision Gen2, Osram CBH, and Osram CBB. CBB is the brightest and whitest out of the bunch.
  5. Greenteapri
    330
    387
    Cypress
    Yeah, I hear that. Why come back to a forum if no one responds to a question. It seems as if most of the knowledgeable modders have gone to other platforms.
    I'll check out your post.
    I went ahead and ordered the Morimorto H11 hid conversion kit. I also have some Osrams as a backup if this doesn't workout.
    Thanks for coming back and answering.
    ksaepharn likes this.
  6. ilovegirls
    ilovegirls Member
    172
    40
    San Diego
    Sorry, I meant to say osram
  7. Greenteapri
    330
    387
    Cypress
    I figured as much. Thanks for clarifying.
    Did you do the retrofit yourself? Any tips?
  8. ilovegirls
    ilovegirls Member
    172
    40
    San Diego
    The your time and make sure you clean the lens before snapping it together.
    When taking apart the lens, go from the corner and make you take off any metal brackets and screws. Pull apart and away from eachother.
    As far as the rx projector install itself, its straight forward when you go to line it up. A little grinding and it fits.
  9. pisetup
    pisetup Junior Member
    Spokane
    Bringing this back to life.
    Is the photo accurate? I’m in the middle of my retrofit project & was hoping to find power under the hood.
