Prius Gen 3 Major Maintenance: EGR, manifold, spark plugs, Oil Catch Can
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wvs2003, Jan 21, 2019.
  1. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    My preference, if going to all that trouble, may as well drain and refill the engine coolant. Same amount of work. He just bought this car with 100K miles and the coolant has probably never been replaced anyway. Just as he’s replacing the spark plugs.
    I agree with replacing the rubber gaskets but not the metal gaskets.
    Raytheeagle and Mendel Leisk like this.
  2. Mendel Leisk
    41,331
    We'll agree to disagree, on the coolant? ;)
    Honestly, it was very easy.
  3. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Both coolant?
  4. Rebound
    3,996
    2,644
    Portland, OR
    In these procedures, you only touch the engine coolant, not the separate inverter coolant.
    One jug of coolant was enough for the engine coolant but I think you’ll need a second jug for the inverter coolant, even though it’s far lower capacity than the engine coolant. Unlike the engine coolant, the inverter coolant fills up very fast and it’s easy to over fill and make a mess if you aren’t careful.
    Both coolants are due at 100,000 miles-ish and if you jack the car and remove the pan for the engine coolant you may as well do the inverter coolant. Make sure you don’t confuse the inverter drain plug with the transmission drain plug.
    Good luck. Wish I was nearby to help you.
    #64 Rebound, Dec 18, 2019
    RMB and Robert Holt like this.
  5. kashanv
    kashanv New Member
    Sacramento
    Update on post OCC and doing the spark plugs
    still not quite getting the Mpg I had before and some burning smells. While investigating that, after 1000 miles there is about 3 tablespoons of oil in OCC and still quite a bit pooled in the intake manifold. I think I will put some more steel wool in, hopefully it will catch more oil before it pools in the manifold.
    scona likes this.
  6. kashanv
    kashanv New Member
    Sacramento
    Also just did a successful head gasket job on my other 2011 Prius if anyone in the Northern California Sacramento area needs a hand, it’s helpful to have another person
    Raytheeagle and Grit like this.
  7. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Steel wool? Bad YouTube info reared it’s ugly head in here again.
  8. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Which CEL codes were thrown prior to head gasket job?
    kashanv likes this.
  9. kashanv
    kashanv New Member
    Sacramento
    Cyl 1 misfire (spark and coil functioning perfectly) + fuel/air ratio issues
    Other signs: lowering coolant even after continuous topping off
    Lowering mpg ~38
    Eventually led to the obvious signs: white exhaust smoke (visible if you shine a light at muffler) and heaving knocking noises on startup
    Robert Holt likes this.
  10. kashanv
    kashanv New Member
    Sacramento
    What’s the better alternative?
    i said “wool” but what I use is the SS dish scrubbers, 2 for $1
    #70 kashanv, Feb 9, 2020
  11. Rebound
    3,996
    2,644
    Portland, OR
    I’m only going to warn you to be CERTAIN that no small bits of steel can break loose. The system is under vacuum and small bits of stainless steel drawn into your engine can damage or even destroy it. Stainless dish scrubbers aren’t built to very high quality standards.
  12. Mendel Leisk
    41,331
    Maybe some thin gauge bare copper wire, bunched up?
  13. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I used them for 30k miles and they were fine:).
    How often do you find little bits of them in your dish water:whistle:?
    I've not seen them disintegrate and that's with a heavy application of force;).
    And all they are doing in the catch can is sitting there with spooge collecting on it:cool:.
    Save the hysteria for politics(y).
    Grit, kashanv and Ed Beaty like this.
  14. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
    Back to the EGR system, I stopped following PriusChat for a few years, so missed the evolving EGR issues.
    Now, my 2010 Prius has 174,000 miles, but has no symptoms, except my mileage is down about 6 or 7 mpg from OEM, at around 46mpg, per the computer. In other words, no oil burning, or noticeably rough running, or DTCs.
    I have time to work on the car, which will become my son's. What approach would folks here recommend? Perhaps start by taking the EGR system apart, and seeing how things look, as a first step?
    #74 pjksr02, Feb 10, 2020
  15. Mendel Leisk
    41,331
    The simplest way to see where you're at, is to check the degree of carbon build up in the EGR pipe, a stainless steel connecting pipe between the EGR valve and intake manifold. Watch @NutzAboutBolts video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Two or three other videos linked there too, for the full cleaning of the intake manifold, full EGR clean, and Oil Catch Can install.
    Good thread:
    EGR & Intake Manifold Clean Results | PriusChat
    Another:
    Oil Catch Can, Eliminate that knock! | PriusChat
    Some tools worth having:
    E8 Torx socket (mandatory)
    E6 Torx socket (optional, but good to have, to remove the throttle body studs from intake manifold)
    3/8" ratchet wrench, regular and long handle, flex head, you can never have enough (or 1/2 plus reducer)
    1/4" ratchet wrench, or 3/8" to 1/4" reducer
    Ratchet extensions: you can never have enough
    Long needle nose piers, straight and bent tip
    Ratcheting 12mm box wrench (optional, but makes disconnection of the EGR cooler from exhaust easier)
    Torque wrench (3/8" and 1/4" both good to have)
    Floor jack and safety stands (or ramps): basically some method to raise front, if you need to take underpanel off, which you may need to, both for access and to recover dropped items.
  16. Mendel Leisk
    41,331
    Also good to clean the throttle body. There's another @NutzAboutBolts video on that. I'd recommend to unbolt it, pull off the electrical connector and lift it right off, for more thorough cleaning. No need to disconnect the coolant hoses; they have enough play that you can lift it up, flip it over and tie it off, suspend it from something adjacent if needed.
    Have a look at the swamp below, in the intake manifold; that's where oil catch can will help. There will be a lot of gunk in the intake, it's really part of the EGR as well, has EGR passageways that need cleaning.
    Also, down at the bottom the MAP (Manifold Absolute Pressure) sensor lurks, probably oil-drenched. By your miles, maybe getting crusty? CRC MAF Sensor cleaner (spray can) is good for that, basically a very clean electrical-contact cleaner.
    Torque values for the throttle body bolts/nuts in one of the attached above.
    NutzAboutBolts, Grit and pjksr02 like this.
  17. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    If it’s certain that no small bits of steel can break loose then it’s safe to use.
    kashanv likes this.
  18. pjksr02
    532
    227
    Connecticut
    Thank you for the Repair Manual sections, Mendel.
    I pulled my EGR tube, and have attached photos. Things don't look too bad, in my opinion, at 174,000 miles. The first photo is from the side at the EGR valve, and the carbon deposits are mostly right at the end (these don't run the length of the pipe. The manifold end is slightly oily.
    Robert Holt and Mendel Leisk like this.
  19. Mendel Leisk
    41,331
    The EGR valve and cooler need a cleaning visit. And the intake manifold. Don't doubt it. You're on the outskirts of head gasket failure city.
    This is what the EGR cooler interior will look like, all the way through:
    You can barely slip a thin gauge wire through the EGR cooler, that's how tight it is. The EGR cooler and valve will have similar crusties. And the intake manifold EGR passageways, same story.
    #79 Mendel Leisk, Feb 12, 2020
    Merkey, RMB and Grit like this.
  20. wvs2003
    wvs2003 Junior Member
    @pjksr02
    By those pics, I agree with @Mendel Leisk . You should clean your EGR system. If you had a pressure washer, you could clean the EGR cooler quickly :) (Referencing to @Raytheeagle )
    Raytheeagle likes this.
