Prius gen 3 plugin nexcell viability
Discussion in 'Gen 3 Prius Technical Discussion' started by Aethergrove, Oct 6, 2022.
  1. Aethergrove
    Aethergrove New Member
    I was wondering if the nexcell was viable for the gen 3 plugin. does anyone have info on it more than what is on their website?
  2. PriusCamper
    PriusCamper Senior Member
    13,440
    5,426
    Pacific Northwest, USA
    They'll be back in stock sometime the second half of this month. And if you use my affiliate link in my signature I'll offer you unlimited tech support indefinitely.
    As for viability for Gen 3, I put the final prototype for cold weather testing in a Gen3 and Gen2 Prius 2 years ago and it has gone great for both packs. You can read the review here: Dr. Prius Packs Less Than A Year Away? | PriusChat
    In general the Gen 3 hybrid system puts a greater demand on the same battery pack as Gen 2's hybrid system. So with OEM NiMH prius battery packs it's common that a Gen3 will wear out a pack faster than a Gen2, but that's measured after a decade of use.
    As far as I can tell, Project Lithium packs will outlive NiMH packs and I'll have way more details about that in 8 or more years.
  3. ChapmanF
    18,997
    Does the Gen 3 plugin take a larger-capacity pack than the non-plugin Gen 3?
  4. PriusCamper
    13,440
    5,426
    I've not worked on an early Gen3 Plugin pack yet, but @black_jmyntrn has one of those and probably has figured out what's possible. Currently NexCell isn't selling plugin Prius replacement packs, but if he eventually does him and @black_jmyntrn will most likely be testing it together because they live in the same area.
  5. Aethergrove
    But I just read in a different post that plugin was not tested yet. Would you advise waiting till it is?
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Cant wait for the details in 8 years, Thread will be put on watch!!!
  7. bisco
    52,814
    no, it will not work. pip pack is 4 x lift back
  8. PriusCamper
    13,440
    5,426
    Do you know where the Weber Auto tear down video of an early Gen3 Plugin is? I tried looking for it on youtube for this discussion, but couldn't find it.
  9. bisco
    52,814
    sorry, idk if there is one
