Prius Gen 3 Restoration pt 1 Engine Bay Cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Grillem007, May 31, 2022.
  1. Grillem007
    Grillem007 New Member
    Patterson, CA
    I just picked up a 2014 Prius that needs some TLC.
    Started with the engine bay cleaning:
    Sprayed key areas with degreaser, waiting a few mins. then used a low to medium pressure washer to spray it all off. The final key step is spraying all rubber and plastic pieces with 303 Aerospace protectant.
    49,429
    congarts and welcome! all the best (y)
  3. Mendel Leisk
    38,700
    The 12 volt cable plugging in atop the AC compressor is prone to retain water, corrode out. I’d disconnect it and blow it dry. To release, a pen knife blade inserted just above the base on the front side and pried outwards releases it easy.
    how many miles on it?
  4. ChapmanF
    15,557
    What on earth is in that engine coolant reservoir? Coffee?
    burebista likes this.
  5. PriusCamper
    PriusCamper Senior Member
    11,089
    4,512
    Pacific Northwest, USA
    At least you aren't the guy who posted on here after he pressure washed his dashboard... But in general I keep engine cleaning to scrub brushes, washcloths and rags. Way less risk of water damage that way.
    Foxglove likes this.
  6. JC91006
    16,479
    8,397
    Yeah that engine coolant looks to have the wrong stuff in there, maybe DEXCOOL stuff. It should be pink like the inverter coolant reservoir.
