Prius Gen 3 strange noise during slow acceleration
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GabrielD, Apr 29, 2021.
  1. GabrielD
    GabrielD Member
    179
    73
    Romania
    2014 Prius+ MPV
    I noticed a very strange noise, when accelerating slow, starting at 30 km/h and after 50 km/h is fading...
    Here is a small mp3, maybe someone can recognise from sound, and point me in the right direction...
    No DTC, nothing... I am planning a test drive with Techstream, but not sure what parameters to observe...
    Later edit, I uploaded here the files
  2. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    No sound file...
  3. burebista
    burebista Active Member
    189
    130
    Romania
    Click on here in his post. :)
    52,863
    no link on 'here'.
    edit, whoops wrong here. found it.:)
    i don't like downloading files though, so i can't hear here
  5. Mendel Leisk
    42,355
    FWIW I’ve often heard a buzz with our 2010, during moderate acceleration, just in a certain zone. Accelerate a little harder, or easier, it’s gone. Not sure what it is; have heard about loose coolant hose bracket, tried zip tying it, but no change. Maybe Exhaust Gas Recirculation valve partially opening, or something like that?
  6. burebista
    189
    130
    Romania
    Come on guys, no need to download anything, you can play it directly.
    It's like a rattle noise.
    jerrymildred likes this.
  7. ChapmanF
    19,037
    Given the choice between "save as an MP3 file and open deliberately in my chosen audio playing app that I know doesn't do anything but decode and play audio" or "have played for me by unknown javascript running in my browser from some web site", I'll go with download and deliberately play every time ....
  8. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Sounds like engine failure
    bisco and Tim Jones like this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    11,119
    6,976
    Texas Hill Country
    Possible wheel bearing
  10. GabrielD
    GabrielD Member
    179
    73
    Romania
    2014 Prius+ MPV
    Thank you for all responses, 100% noise coming from engine, not wheels...
    I learned how to "produce" it: it starts only after few minutes of drive, never on cold engine, and right now I will go to record live data during this noise...
  11. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Sounds like it could be the electric motors but to hard to tell.
  12. Mendel Leisk
    42,355
    How many miles?
  13. GabrielD
    GabrielD Member
    179
    73
    Romania
    2014 Prius+ MPV
    Aprox. 130.000 miles...
    Btw, Techstream does not read and display this info for my car, but my friend with Auris (same engine) yes, using same laptop... could be something wrong?
  14. GabrielD
    GabrielD Member
    179
    73
    Romania
    2014 Prius+ MPV
    I managed to record data from my Prius and my friend's Auris (same engine).
    I did compare the .TSE files and results are here (Current=Prius, Reference=Auris).
  15. bisco
    52,863
    ah, i was wondering why i couldn't hear the sound :oops:
  16. GabrielD
    GabrielD Member
    179
    73
    Romania
    2014 Prius+ MPV
    After a lot of studies, I found a very good procedure to follow in many cases engine is rattling...
    Just take out the EGR valve connector.
    I did this to my car, after I was sure I reproduce the error. After that, no more noise and shaking coming from engine...
    I started new test with Techstream, vehicle in parking, engine run, about 1400-1500 rpm.
    Started a test for EGR step position and around 30-35 step noise and shaking started to come. Continuing to open the EGR valve, about 45-50 steps defect disappears. I continued to fully open the valve, nothing noticeable...
    So, I am now 80 % sure the issue is in EGR valve area... First thing I will take out the valve to check if when Techstream says 0 step, valve is fully closed, than, visual check all the way long until fully open, at 110 steps...
  17. privilege
    privilege Active Member
    659
    169
    Birmingham
    sounds like a bad wheel bearing, worn axel splines, or slop in the drive train...
    but it could be a cabin vents (reeds) flopping in the breeze too
    hard to tell
  18. GabrielD
    GabrielD Member
    179
    73
    Romania
    2014 Prius+ MPV
    Thank you for your answer, but this sound is almost elucidated, as I wrote in post nr. 16.
    I took out EGR valve connector and the sound disappeared, for sure if it was wheel bearing, the noise where still produced...
  19. Mendel Leisk
    42,355
    Get that Exhaust Gas Recirculation (and intake manifold) cleaned. At 130k the clogging will be well along. More info:
    Bad Flywheel | PriusChat
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    not bad, I won’t even read so my replies are random answers
    bisco and burebista like this.
