Prius Gen ii - Alignment Question or Help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by deletejunkemail, Aug 13, 2019.
  1. deletejunkemail
    deletejunkemail Junior Member
    Hi Prius Chat Folks!
    I'm trying to use the EZ Shims for my rear camber that is off...
    Here's a pic of the alignment check chart:
    As you can see from the photo of the alignment check, i'm focusing on the Toe on the Rear Right.
    EZ Shims or SPC 75600 Yellow
    https://www.spcalignment.com/index.php?option=com_spc&task=part_description&pid=75600
    My plan is to add about 1.44° of toe in which would look similar to the Rear Left Toe of (+.021°)
    - Is that the correct amount of Toe change I should be doing to achieve the goal?
    - Should i be using a different toe positive degree?
    Here is the settings i used per the Shims Chart provided:
    - I decided to go with the 1.44° which would give a (-.50°) of Camber with the Shim kit using the numbers 28/28
    Would this be the appropriate way to address the Rear Right Toe?
    Considering the Total Toe would change it to (+.42°), is that what i want or should I change the Rear Right Toe to add about (+1.01°) to make the total toe close to Zero?
    My current Thrust is 0.72°... is that a lot? I assume that means its going towards the 1pm'ish direct?
    Thanks in advance for your help and time!
