Prius Gen II HID headlight Question
Discussion in 'Gen 2 Prius Main Forum' started by PRwanting, Sep 13, 2012.
  1. PRwanting
    PRwanting Junior Member
    48
    Boston, MA
    So the passenger sides HID headlight of my friend's 2005 Toyota Prius died out. Toyota dealer gave him a price of around $350 to fix it. Is there can other way to buy them cheaper anywhere else? The prius is outrageous for a headlight bulb. Anyone knows any place/ website?
  2. PRwanting
    48
    Boston, MA
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    If its just the bulb, that's pretty easy......just follow the vid. If its the ballast, ull need to remove the bumper & headlight. If ur not sure which it is, swap the bulbs & see if the outage follows
  5. PRwanting
    48
    Boston, MA
  6. Ronnie_Ringo
    Ronnie_Ringo Junior Member
    Chicago
    Do a search on this forum about headlight issues. There are plenty of threads that discuss this. The bulbs can be bought on Amazon for 50 bucks each. Youtube has plenty of vids that will help. 100 bucks and about 30-60 minutes of your time should be all you need to change out both bulbs (which is recommended when the first one goes).
  7. Metrolens
    Metrolens Member
    215
    Hi all - I have a 2005 Prius, and the driver's side headlight has started to turn off occasionally while driving. I can turn off/on the lights, and it fixes the problem temporarily, but then the bulb will usually go out again after a few minutes.
    So, I should install a new bulb, right? Might this be covered by some warranty or factory recall? (There are over 60k miles on the car.)
  8. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Yes to the first. No to the 2nd. See Toyota Prius Class Action Lawsuit | Toyota Headlight Lawsuit | Girard Gibbs LLP.
    Toyota switched to D4R bulbs on the 06-09 Priuses from the more reliable D2R bulbs on the 04-05 Priuses. You really think an automaker is going to warranty bulbs for 7 or 8 years? When's the last time that's happened?
    04-05 (NOT 06-09) Prius owners w/HIDs - how long did they last? | PriusChat shows how much longer the D2R bulb seemed to last.
  9. Metrolens
    Metrolens Member
    215
    Thanks Cwerdna. I recall seeing something about a factory recall, so I thought I'd ask.
    I bought the car used two months ago with a shade under 60k miles. From that "how long did they last" thread, it seems like my 2005 is on the very fast side of an HID dying out.
    My driver's side bulb (the bad one) throws a more bluish tinted light than the passenger side bulb. Is there an explanation/some significance to that bluish tint?
  10. Metrolens
    Metrolens Member
    215
  11. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    I doubt those will work unless you retrofit your headlights or your Prius didn't come w/HIDs in the first place. HIDs are driven at high voltages and have a ballast vs. being driven at 12 volts. See Not all HID Bulbs are created equal | PriusChat.
    Toyota used to charge $300 for a replacement D2R/D4R (now only $150, at last check). And, they used to unnecessarily replace the ballast (even more $) while also usually removing front bumper cover (yet more $).
  12. Metrolens
    Metrolens Member
    215
    Thanks again cwerdna.
    Any thoughts on the difference in color temp between my two bulbs?
  13. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Personally, I'd only replace the bulb that's failing. I don't notice a color difference between my bulbs. I would try to buy bulbs w/the same color temp rating as your existing one.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    You buy new bulbs (replace both at the same time) from here:
    D2R: Morimoto 3Five (35w) - HID Bulbs from The Retrofit Source Inc
    Ur car uses a very reliable ballest......the D2 Denso ballasts are considered 1 of the best in the market so I wouldn't change them yet till u get the bulbs replaced.
  15. Metrolens
    Metrolens Member
    215
    Hi again, so I tried to install the new bulb in my 2005 Prius.
    It basically seems impossible. I couldn't get beyond step one in the video above (remove fusebox cover). I do have somewhat big hands, so that may be the problem, but it was impossible to even remove the electrical connector - I tried to pull it off with considerable force, but it wouldn't budge. The angle is so awkward and inaccessible. I also couldn't budge the circular plastic casing. Tried to unlock it (turning it TOWARD driver side door) but it wouldn't move a millimeter.
    How the &*^* are people doing this? Am I doing something wrong?
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The only other way would be to remove the bumper so u can remove ur headlights
  17. Metrolens
    Metrolens Member
    215
    I won't be able to remove the bumper myself.
    Can anyone else advise on what I may be doing wrong?
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Maybe some local member can help u out. Where are u located?
  19. Metrolens
    Metrolens Member
    215
    I'm in Los Angeles.
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Where. I'll be in commerce tomorrow and could help u after work.
