Prius Gen III 12V Battery Available at Costco?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Apr 4, 2015.
  1. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    No that comparison is the AMP/HOUR capacity.
    And sometimes the absolute lowest price is NOT the best deal in the long run.
  2. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    51,950
    $165 for the battery? i could live with that. great installed price too, thanks!(y)
  4. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Right, except it's amperes TIMES hours, not amperes per hour. For batteries that have reserve capacity ratings (meaning the battery can last X minutes at 25 amperes), that might be equally or more relevant, depending on the drain rate you're concerned about.
  5. Easy Rider 2
    1,584
    258
    Ocala, FL
    OK, so Amp/Hours is not the right way to express that.
    What is ? Amp-Hours ?? OR AmpHours ?? I have never seen it written as Amp*Hours.
  6. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    It fit! I took out the old and drop in the new, no modification the mount or bolts. The new one is heavier than the OEM AGM. No regret but piece of mind for the next 4 years.
  7. bisco
    51,950
    what is it, lead acid?
  8. Mike500
    Mike500 Senior Member
    2,593
    767
    ALL 12 volt Prius batteries are lead acid.
    I checked my Batteries plus store, today. They had one on the shelf. It had the smaller J.I.S. terminals.
    That's where I'm going when I will need one. The guy was rebuilding a 7.2 volt ni-cd RC hobby battery pack on the bench and soldering the connectors to it. They are NOT just sales persons.
  9. bisco
    51,950
    why would it be heavier than the oem?
  10. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    More lead. Doesn't it have a higher ampere-hour rating?
  11. bisco
    51,950
    interesting, thanks.
  12. Jackie V
    Jackie V Junior Member
    Cincinnati, Ohio
    I just purchased the Optima 8171-767 DS46B24R yellowtop for under $150 included 2 day shipping from Amazon.
