Prius Gen2 Traction Battery Experience
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jdenenberg, Apr 21, 2011.
  1. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 Prius began to have HV battery problem symptoms at 194k miles,
    • The ICE RPM went higher than normal when accelerating or going up hill
    • The SOC fluctuated rapidly
    • MPG, however, seemed OK
    Then about a week later the dashboard lit up like a christmas tree [​IMG]
    The OBD2 code was P0A80 which confirms the failed traction battery. I had expected it to last 250k to 300k miles, Oh well.
    My Prius now had some new symptoms since the ecu knew there was a problem:
    • MPG dropped a bit
    • Cruise control was disabled (Probably AC too, but I didn't check it)
    • No help accelerating from the MGs - Only the ICE so a bit sluggish
    I checked with Dave at Re-InVolt in NC and he could ship me a refurbished battery for $1475 plus $125 shipping to CT as long as the shipping address was a commercial site. He did not have any installers in CT.
    I contacted my usual Toyota dealer and he priced a new battery as $3300 installed. I talked him into pricing using a battery that I supplied and after informing him that it would be a drop in (fully equipped with the required electronics) he said 4 hours ($360 plus tax - installing a Toyota battery is a 5 hour job).
    The battery was shipped directly to the dealer and was installed (Dave now has a CT installer). My Prius is back up and running like new. I expect that the Re-InVolt battery starts out with some previous use, so I expect that its life may be about 50k miles less than a new one, but we'll see.
    So all in all not a bad experience. Under $2000 after 194,000 miles is a penny per mile (for comparison my tires also run about a penny a mile - $500 every 50k miles).
    JeffD
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Thanks for the info!
    Did you also hear the battery fan running more or at higher speeds than it normally does?
  3. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Hi Jeff;
    I would have expected more than 194, but then again that is probably above average? I think that is just part of owning one hell of a machine. Good luck with your new pack!
    Cheers;
    Hal
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Excellent post, thank you.
    Did the shipping costs include returning your old battery to RE-involt ?
  5. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I was lucky, Dave had a surplus of salvaged batteries and didn't need mine. Now I can part my old battery out on eBay :)
    JeffD
  6. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I didn't notice the fan running, but it was in cold weather.
    JeffD
  7. bisco
    49,003
    great story. i'm amazed a dealer would install a used battery. that's a pretty class act.
    Meg&Bear likes this.
  8. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    At that high mileage/yr, I presume they are mostly highway commutes.
    What kind of highway miles did you put on it ?
  9. SageBrush
    11,627
    2,530
    Southwest Colorado
    Is that so much better than collecting a bounty from Toyota ? I do not know specifics of the Toyota recycling rules, but you might be able to resell the electronics and just return the battery.
  10. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Generally speaking, only a dealer can collect the $200 bounty, and it does not get passed along to the customer.
  11. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    That is nice to know at least one dealer that was willing to install a non-Toyota battery to help the customer save some money.
    Nice write-up.
    Thanks
  12. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    ok, i'm sure this is a stupid question....
    what is a traction battery? is this the hybrid battery, the 12V battery, or something else?
  13. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    The traction battery is the "hybrid battery", the big silver box behind the back seat that runs most of the width of the car. You might also find http://www.myprius.co.za/technical.htm insightful.
  14. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    It's the large, nickle metal hydrid battery pack. You'll see it called the HV pack, they hybrid battery, the traction battery, the big battery, etc.
    The 12v will be called either that or the accessory battery in most cases.
  15. striker308
    302
    43
    Thanks!
    I just tested the 12V and under load it shows 11.8 (time for a new one) the car started with a lock issue I remembered reading about on here and that one ting to check was the Fob battery then the 12V battery.
    is the OEM the best bet for a replacment?
  16. Patrick Wong
    18,200
    6,464
    It is the easiest bet in terms of installation effort.
    Whether or not it is the best bet depends upon your local dealer pricing for it (MSRP is $138.70) compared to the price of an Optima battery which many owners here seem to like.
  17. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It helps when you have a long term relationship. I've trained them in Prius maintenance for 7 years.
    • 3 ATF refreshes - They questioned the need at first
    • Coolant refreshes twice (Water Pumps at 150k miles)
    • Plugs & PCV at 100k
    • Upper Steering column assembly repair at 150k
    JeffD
  18. TommyG
    TommyG New Member
    harvard, ma
    Hi Jeff,
    My '05 Prius has had the same issue this week at 120k miles, all the warning lights, no cruise control, sluggishness, battery fan constantly running, lower gas mileage, and the P0A80 code. Dealer quoted me the same $3,300, but said they won't install a 3rd-party battery. So i'm wondering a few things:
    1. How you succeeded in getting your dealer to do it?
    2. What kind of warranty did you get on the battery and installation?
    Thanks.
    Tom
  19. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Was your Prius purchased and operated in MA? Currently, MA is a CARB emission states and would receive the 10 year/150K mile HV battery warranty. I don't know if it was a CARB state back when you car was purchased.
    Can you check your warranty booklet for the inclusion of MA in the California warranty?
  20. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have had a long relationship with this dealer in CT (A1Toyota - 2 hours from you, talk to the service manager) and they may do it for others as the experience was good.
    Re-InVolt gives a 12 month/Unlimited mileage warranty (same as Toyota). The dealer just did the installation and checked it out before delivery.
    There are some useful shops around the country that can get a Prius with a HV battery problem back on the road for less than a dealers $3k+. Ones that I know of are in CA (Arts Auto, Luscious Garage), North Florida (Forgot the name, do a search), Indianapolis (AutoBeYours) and, of course, NC (Re-InVolt).
    I also noticed a "Hybrid Certified" repair station just northeast of Harvard when I used to drive to my son's apartment. Check around.
    JeffD
