Prius Generations
Discussion in 'Gen 2 Prius Main Forum' started by john1701a, Feb 14, 2009.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Ok, didn't really doubt you, just wanted to double check b/c it seems so incongruous with the previous torque ratings.
    Where are the engineers when we need them to explain this change to us?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    Also for sources, do some searches on "Argonne 1998 Prius" paying close attention to the published PDF papers. It's pretty interesting reading stuff from way back before most people knew what the heck a hybrid was.
  3. Arniesea
    Arniesea New Member
    26
    Bremerton, WA
    John, I just went to your web site and looked at the PSD digrams. How cool!!! What an elegant bit of engineering! Thanks for the wealth of info you provide for us new owners.
  4. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Dang, the one thing I was looking for on the chart was mpg. A little effort is required to adjust for the EPA methodology changes, but everything else on the chart is engineered to achieve those mpg numbers.
  5. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    I am confused by John's table. In much of the previous narratives the Traction Motor has been designated as MG2, with MG1 being the smaller motor/generator supplying electrical power to drive MG2, in addition to providing torque for starting the ICE.
    It also provides resistive torque under heavy acceleration to MG2 and the ICE.
    If the Traction Motor (TM) in the G3 Prius is providing lower torque levels than the G2 variant, the only explanation must be that the PSD gearing and final drive ratios have changed. That would also require a change to the TM maximum RPM (higher?) too, would it not?
  6. john1701a
    12,840
    5,311
    58
    Yup, I mixed them up. That's why asking for feedback has become standard practice. Focusing so hard on making sure the quantitative values themselves are correct, you tend to overlook things like labels.
    Fortunately, I got quite the jump on this rollout. Having all my ducks in a row before delivery begins will be great!
    Thanks for the verify.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    To remove the North American-centric nature of the chart you could include that outside NA the stock tyre width is 195mm but like you say John, you want to keep it simple. It's a good job.
    Could you include 3 more lines?
    Total interior space in cubic feet or litres
    Luggage space in cubic feet or litres
    Passenger space in cubic feet or litres
    These are areas where there have been constant improvement and if your not carrying anything or anyone in a Prius it's just an ornament.
  8. john1701a
    12,840
    5,311
    58
    That's one reason why model years aren't shown at that level. Lots of variations exist from place to place, and it would nice to document that too... but in categories.
    My guess is the next effort will be a second chart, documenting stuff like the space info.
  9. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Hi John,
    Thank you for the table.
    I had an opportunity to see a preliminary Toyota shop manual and I would like to comment some...
    * max MG2 rpm is 13,500rpm.
    (I believe we heard the max MG1 rpm is 13,500 at PCD, but Chief told us wrong information, maybe.)
    The shop manual says battery power is increased from 25kW to 27kW. I believe the MG1 kW is ...
    * MG1 kW is 60kW(motor)-27kW(battery)=33kW
    (The Iconic MG1 kW is 50kW(motor)-25kW(battery)=25kW)
    Anyway, my dealer told me the final shop manual will be available by mid March.
    I'll try to update these information then.
    Ken@Japan
  10. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Gears.
    Gear ratios reduce revolutions and increase torque, or vice versa.
    Let's say we have a pair of gears with 30 teeth on the drive gear and 60 teeth on the driven gear, a ratio of 1:2. For every revolution of the drive gear, the driven gear moves half a revolution: we have to turn the drive gear twice to get one revolution of the driven gear.
    Say the torque is (arbitrarily) 100Nm. Say our drive gear is 20cm (0.2m) across. Torque is force multiplied by distance, so at the teeth, the force is the torque divided by the distance, so here it would be 1,000N (because we're looking at the radius, not the diameter). Our driven gear is twice as big to accommodate all the teeth: therefore the torque is 1,000 x 0.2m = 200Nm.
    If I recall correctly, from a diagram I saw here, the Camry Hybrid setup has MG2 driving the sun gear of the second planetary set, while the ring is coupled to the first planetary set and the final reduction gear - the planet carrier is fixed. I'm not sure how that works out in terms of ratios.
    Frankly the motor manufacturers might as well not quote half the stats they do, as they're effectively meaningless - they're basically playing [ame="http://en.wikipedia.org/wiki/Top_Trumps"]Top Trumps[/ame] with each other. The important statistic is how much force is actually applied to the road, which is a function of the engine output torque at the current engine speed, and the selected gear ratio.
    MG2 may well max out at 13,500 rpm, but if the final drive ratio is the same as the earlier cars, that would be a top speed of something like 200mph. Clearly that's not right! Again, the division of the gear ratio corrects this.
  11. efusco
    19,891
    1,196
    Nixa, MO
    Of course!! Dang, how soon we forget stuff. The new transaxle has a dual stage/phase/whatever set up.
    John, that oughta be on your chart, at least as an "*" after the MG2 torque. It's a significant engineering change in the 3G and helps clarify the issue of the torque differential.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Speed Reduction Unit in the Camry hybrid multiplied MG2 torque by 2.48 times. We'll have to see if that's the same for 3G Prius.
    Dual stage would add a third PSD and two clutches. I am still not clear (due to conflicting info) if 3G Prius will have dual stage. So far we have only seen the dual stage in the Lexus RWD performance hybrids.
  13. Patrick Wong
    18,210
    6,514
    Hi Ken,
    Please tell us more!
    Hi Evan,
    Please note that we also were given the torque ratings and other data, printed in the Media Information DVD jacket.
  14. nameless dude
    nameless dude New Member
    77
    Sydney
    18kws of extra power manages a better 0-60 time of 0.3secs. A result of all that loss in torque?
  15. Tideland Prius
    16,631
    I am questioning that 0-60 time. The current one ranges from 10.1 to 10.5 depending on sources. Toyota themselves said it was 1 second faster (which meant their testing yielded 10.8 sec). We won't know for sure until the magazines start testing them and we get to drive the vehicles ourselves.
  16. patsparks
    10,664
    567
    I believe the 2 stage refered to is the final drive reduction is 2 stage, that is there is a primary and secondary gear reduction. There are no clutches or changable ratios. I don't know if the chain drive in the iconic Prius was a reduction ratio or just a way to get the drive out from between the 2 motors?
    I could be wrong, I was wrong once before ...
  17. Mike Dimmick
    963
    249
    Reading, UK
    Looking at Art's transaxle teardown, the chain drive in a classic Prius looks like it was 1:1. It couples the PSD ring gear to the main reduction gear, which drives the differential.
    If I recall correctly the repackaging of the new transaxle means no more chain drive, which hopefully will reduce the slack and therefore the distance rolled when the car is put in Park.
    It doesn't really matter how the drive gets there, but there is an additional ratio between MG2 and the wheels that wasn't there before, so the reduction in actual motor torque is multiplied back up with no change (or even possibly an improvement) in torque at the wheel. It may be that the change means greater torque across a wider rev range compared to the Iconic Prius.
  18. patsparks
    10,664
    567
    I reduce the roll distance in park by using the park brake, works great.
    I wonder what the overall final drive reduction is compared to the Iconic, because MG1 spins faster it can be geared lower yet still maintain the same or lower engine revs. Yep, this might more than make up for the overall torque reduction.
  19. efusco
    19,891
    1,196
    Nixa, MO
    Yea, came across that yesterday. It just didn't ring any bells or take any significance until I saw the dramatic drop in torque on John's chart.
  20. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Not less torque at the drive wheels, just less torque at MG2. MG2 is more powerful on the 2010, but develops the power at higher RPMs, requiring gearing. MG2 is also smaller and lighter.
    We were told 9.8 seconds at the show in Detroit.
    This is still somewhat fuzzy. Attempts to clarify have been inconclusive. I wish Prius Team would come up and give us a conclusive answer.
    Tom
