Prius Handling Problems at Highway Speeds
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ARiddle, Apr 5, 2006.
  1. Abq Richard
    Abq Richard New Member
    59
    Albuquerque, N.M.
    I've had my Prius for 10 days, and here's what I've been experiencing: The car does not want to drive in a straight line. When I'm driving down the highway - a smooth highway here in New Mexico - it will head off a bit toward one side. I'll correct, but instead of driving straight down the lane, it will head off toward the other side. I can't get it to drive in a straight line, and I'm constantly having to adjust to keep it in the lane, much more so than I have to do in my trusty old 4Runner. I haven't experienced the darting that some other posters mentioned. I thought there must be a slight alignment problem, but after reading this thread I'm wondering if my experience may not just be normal for a Prius. I'd appreciate any feedback on my experience.
    BTW, I just discovered this site yesterday, and it's great! Very informative, intelligent posters, and some humor to boot. Thanks to the those responsible!
  2. benighted
    benighted New Member
    530
    Westport, WA
    <div class='quotetop'>QUOTE(abqrichard @ Apr 7 2006, 07:21 PM) [snapback]236601[/snapback]</div>
    What you describe is exactly how mine was acting before I had it aligned, I think it is actually how they are supposed to drive but I didn't like it.
    Make sure you ask for toe-in, that will help hold the steering wheel at center.
  3. s.e.tx_parrothead
    s.e.tx_parrothead New Member
    130
    Huntsville, TX
    Quick question about the alignment.....The hubby wants to know how the toe-in alignment and increased air pressure affect tire wear??? Thanks!!!!!!!!!!!!
  4. benighted
    530
    Westport, WA
    Toe-in slightly increases tire wear (but I think its well worth it) while having more pressure usually reduces tire wear.
  5. s.e.tx_parrothead
    130
    Huntsville, TX
    <div class='quotetop'>QUOTE(benighted @ Apr 7 2006, 10:46 PM) [snapback]236644[/snapback]</div>
    Thanks for the info!!! It is appreciated as is all info gleaned from this site!!!
  6. Abq Richard
    59
    Albuquerque, N.M.
    Thanks for the feedback, benighted. How did the toe-in effect your gas milage?
  7. benighted
    530
    Westport, WA
    <div class='quotetop'>QUOTE(abqrichard @ Apr 7 2006, 09:25 PM) [snapback]236662[/snapback]</div>
    No Problem. I didn't notice any effect on gas mileage.
  8. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(ARiddle @ Apr 5 2006, 06:31 PM) [snapback]235547[/snapback]</div>
    This issue has come up before and some “fixes†work better than others. I think you’re referring to highway “tracking†correct? How well the car holds a straight line on the highway?
    First of all, it appears only a minority of +2004 Prius have this issue, and then in varying degrees. The car is narrow and tall, that probably doesn’t help matters.
    Upon delivery mine was borderline, especially compared to my parents 2003 Buick LeSabre - at Trans Canada speeds one finger on the wheel is all you need. I’d have to describe my Prius as “twitchy.†I also had a 1993 Honda Prelude that was “twitchy.â€
    Unlike your dealer, mine readily agreed there was a problem especially on roads damaged by heavy traffic (Grooves under each wheel due to overloaded transport trucks). They did a couple of complimentary alignments to factory spec and even put the car in their collision shop to confirm the unitbody wasn’t tweaked. It wasn’t.
    The alignments helped reduce the twitchiness by about 50%, then I put on Michelin Harmony and the twitchiness was further reduced. I believe it was forum member 200Volts who suggested moving the little chin spoilers to the very front of the car.
    I tried that and the problem completely went away. However, there is no way I could drive around here in winter with the chin spoilers sitting at the very front of the car, the first patch of frozen slush on the road and they’d be crushed. So for winter I moved them to the stock position.
    When I put on my winter tires, I fully expected the problem to get much worse, as most winter tires have soft squishy treads and a lot of sidewall flex. The first winter I ran Dunlop Graspic DS-2 and they actually *improved* the highway tracking. Second winter I ran Yokohama Ice Guard winter tires, which had much better ice and snow traction over the Dunlops, and those things were squirmy at highway speeds.
    I played around with the chin spoilers and if you move the inboard edge about 1.5cm towards the front of the car, you get almost the same improvement as moving them to the very front of the car. Plus I can then leave them alone all year round instead of moving them in preparation for winter.
    My dealer is still very involved in this matter and still offers a complimentary adjustment every 6 months. They’ve also modified the toe settings and just beyond factory specification, the car tracks almost like my parents much heavier LeSabre. There is no effect on tire wear or fuel economy that I’ve noticed.
  9. jayman
    13,439
    640
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(RichBoy @ Apr 6 2006, 09:53 PM) [snapback]236122[/snapback]</div>
    Wow I'm gone 2 weeks where did this prick come from?
  10. ARiddle
    ARiddle New Member
    44
    <div class='quotetop'>QUOTE(ARiddle @ Apr 6 2006, 11:46 PM) [snapback]236244[/snapback]</div>
    After a few more days and 100's of miles of driving on the 405 the Hydroedges have broken in a bit more. I pumped the pressure up to 40/38 and I can defintely say that "tracking" and "jumping around" in the raingroves has greatly reduced. Also, when the car is buffetted by passing traffic and wind it still rolls a bit but doesn't require corrective steering to stay in lane. It is now much more comfortable to drive at 65+ as a result of the BT Plate and the Hydroedges. Mileage appears to be down about 1.5 MPG from the Comfortreds.
    Tomorrow is the alignment check.
    <div class='quotetop'>QUOTE(jayman @ Apr 8 2006, 09:32 AM) [snapback]236784[/snapback]</div>
    What and where are "chin spoilers"?
  11. jayman
    13,439
    640
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(ARiddle @ Apr 9 2006, 07:43 PM) [snapback]237308[/snapback]</div>
    Those tiny little spoilers in front of the front tires. They're very hard to notice unless you're looking for them.
  12. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(jayman @ Apr 8 2006, 12:57 PM) [snapback]236799[/snapback]</div>
    Most likely some jackass Prius driver trying to perpetuate the SUV drivers are jerks stereotype.
  13. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(benighted @ Apr 7 2006, 08:46 PM) [snapback]236644[/snapback]</div>
    No, increasing tire presure does not reduce tire wear - you'll cause the tire to ballon up if you use too much and the tire rides only on the middle. This is where people think it's reducing tire wear, the edges of the tire are not wearing out quickly because they're not touching the ground! If you look at the center of the tire, it's wearing too quickly.
    Also, over-inflating a tire reduces traction, since you have less rubber on the ground. You'll get better mpg since you have less drag, but the issue of the car wandering would be increased, and stability, handling, and breaking ability would be decreasd. Go to a straight-line track and watch the 1/4 mile guys take air out of their tires for their drive wheels so they can acceletrate better and have better ability to keep their car straight.
    Anyway, if anyone increases air in their tires beyond the tire's rating, get dirty and put your head on the ground, look at your tires dead on with some light behind it and make sure that your tire is flat where it's supposed to be, making good contact with the road. After an oil change, run your fingers over the tire and see if the sides feel newer than the middle.
    Oh, and if you put too little in and the sidewalls of the tire are touching the ground, you'll cause the tire to at best will de-bead and suddenly deflate, or burst into itty-bity pieces. Having too little will reduce the ability to change direction smoothly.
    <div class='quotetop'>QUOTE(DocVijay @ Apr 9 2006, 06:55 PM) [snapback]237338[/snapback]</div>
    On the net, people who do that are called 'trolls'
  14. DocVijay
    1,455
    Tampa, FL
    Well, this morning I was driving across the Sunshine Skyway Bridge and there were very high gusts of wind, approaching 35 mph. I was thinking about how bad the Prius is in strong crosswinds, but hten I noticed that all the other cars were weaving back and forth because of the wind too. I think it may just be that the car is lighter, so we feel smaller gusts that bigger cars don't.
  15. ARiddle
    ARiddle New Member
    44
    <div class='quotetop'>QUOTE(ARiddle @ Apr 9 2006, 05:43 PM) [snapback]237308[/snapback]</div>
    I took the 2006 Prius into the dealership this morning to do the alignment check that I insisted on - still feeling uncomfortable about the tracking and handling of the vehicle. I asked the dealership for a before and after readout of all alignment issues.
    Surprise... Surprise! tHE CAR HAD BEEN DELIVERED WITH A .27 TOW OUT ON ONE WHEEL.
    Accordingly, the dealership acknowledged that this alone could cause handling problems at speed and also reduced tire mileage and excess wear. The dealership is reporting this problem to Toyota.
    After the adjustment, the car does indeed handle even better - and glide better - although the dealer wanted me to try the factory recommended 0 toe-in before they applied more (which they agreed to do on my request after I drove the car this way for a while).
    So the moral of this story is - if you are experiencing handling problems with the Prius at speed is to do the following:
    1. Insist that the Dealership check the alignment/toe-in of the vehicle and correct. They won't expect this to be a problem on a new vehicle and so might not check it at your first complaint.
    2. Replace the Goodyear Integrity tires with ones with better handling characteristics - from my experience with several tires and study of many reports here and elsewhere, the Michelin HydroEdge or Goodyear TripleTred's have excellant handling at speed. Goodyear Comfortreds are another option with their quiet and comfortable ride, but have a slightly more vague centerfeel at speed. Consider pumping up the tire pressure a little more than the factory recommended 35/33 - but don't overdo it. I am at 39/37 right now and may back down a bit now that other issues seem to be handled.
    3. Consider the BT Brace to stiffen the car - especially if you find the car overreacting to wind buffeting and road irregularities. It does seem to make the car more relaxing to drive.
    4. Mention to the dealership and complain to Toyota about poor handling of the vehicle. The dealership politely suggested than most of their Prius customers in the past were not the type of folks who primarily drive on the highway at speed (read BTL "older folks" ). this being changed somewhat by the rush to get in the Diamond Lane. With more feedback, Toyota will improve the cars handling.
    I wish we could make this one a sticky so others coming to the forum with this issue can quickly find this summary.
  16. Begreen
    Begreen Member
    670
    Western WA state
    <div class='quotetop'>QUOTE(ARiddle @ Apr 10 2006, 10:55 AM) [snapback]237573[/snapback]</div>
    Heh, heh. I've felt this anomaly at 55 mph and at 65mph. It has more to do with the road surface, slope, curve angle, and conditions than it does speed.
    Thanks for the post. Looks like I'm going to have to take the car into the dealer for a check. I was hoping to wait until 5000 mi. but now I want to see if this is the root cause of the problem.
  17. hschuck
    hschuck Member
    385
    17
    bay city, ca
    Think pressure. Increase steering wheel pressure in the direction of the correction for deviations as opposed to consciously turning the sw. The steering is so tightly coupled that a perceptible sw movement can be an overcorrection when at speed.
    After giving this suggestion to my wife, riding with her became (somewhat) less frustrating to me.
  18. gilahiker
    gilahiker New Member
    186
    New Mexico
    . . .The car does not want to drive in a straight line. When I'm driving down the highway - a smooth highway here in New Mexico - it will head off a bit toward one side. I'll correct, but instead of driving straight down the lane, it will head off toward the other side. I can't get it to drive in a straight line, . . .
    <div class='quotetop'>QUOTE(hschuck @ Apr 10 2006, 02:17 PM) [snapback]237691[/snapback]</div>
    I agree with hschuck and it does take awhile to learn how to drive the Prius with its sensitve steering. Plus, installing a BT Stiffening Plate really does a nice job of increasing the stability of the vehicle. Especially in these high winds we've been having.
  19. benighted
    530
    Westport, WA
    <div class='quotetop'>QUOTE(Vagabond @ Apr 10 2006, 03:16 AM) [snapback]237434[/snapback]</div>
    I'm going to have to disagree there, kind of. If you run TOO MUCH pressure, it will baloon up but that is what MAX ratings are for. There shouldn't be a problem with uneven wear as long as you stay under MAX. I run mine 42/40 and i still get slightly more wear on the outsides of the tires.
    Taking air out of tires can increase traction if you need to. I've been in many sitiations here driving on the beach and the sand gets soft where if you lose momentum, just run the tires on the drive wheels down to 10lbs then gently rock back and forth until you can get going again.
    Good advice. ;)
  20. dipper
    dipper Senior Member
    1,242
    252
    When I gave the Prius to my wife, I warned her of the Prius' sensitivity with the steering.
    When she started driving, she went.. what are you talking about. She said the Prius was way more stable than her old 1996 Camry.... which I have to agree.
    So it really depends on where you come from. I drove the LX470 and s2000, so I could tell the difference (LX470 went bye bye for the Prius). But even the LX470 would be a nightmare with strong winds... just that the steering does not suck like the Prius.
