Prius headlight goes off after some time
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fegeg, Apr 5, 2014.
  1. fegeg
    fegeg Junior Member
    Atlanta, GA
    Did anyone face this issue?
    One of the headlights will turn off after some driving time. If I turn the light off and on it will come back on.
    Asked Toyota, of course they said it is because you are not using OEM Toyota bulbs.
    I have the same bulbs on both sides. I even replaced the bulb on the "bad side".
    Still the same issue. If the bulb is the problem, it would just be off, why it comes back on after "off/on" exercise?
    Another symptom I saw last week. When switching to high beam light both lights go off. "Off/on" of the car resolved this. This happened only once though.
    The car was in the front accident 2 years ago and Toyota repaired it with life time warranty. But I am not sure if it related or not and how to convince Toyota that there is an issue here and not a "bulb" issue.
    Please help!
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    HID type bulbs? If so, there are plenty of stories about quality issues with other than Phillips bulbs.
    With a front end accident, there could be wiring harness issues, where one of the wires has a slight insulation fault, and is intermittent during normal road vibrations.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Last time I checked...any bulb OEM or otherwise needed current to illuminate, and a lack of current to NOT be illuminated.
    If your headlights are illuminating and NOT illuminating, then illuminating again, it would seem obvious to me that the problem is on the current feed side of the equation.
    How to convince them? Would it be possible to simply install OEM bulbs? Sometimes the path of least resistance is to play the game. Shouldn't have to be manipulative in that manner, but if they are going to say it's because the bulbs are Non-OEM, then the easiest way to show that isn't the case, would be to have the problem manifest while using OEM bulbs.
  4. fegeg
    fegeg Junior Member
    Atlanta, GA
    nh7o,
    yes these are HID bulb
    The Electric Me
    OEM bulbs are $160(!) ...
    And I absolutely agree with you on the logic of the current.
    It is still a mystery, why they come back on after "off/on"....
  5. Patrick Wong
    18,210
    6,526
    So tell us what HID bulbs you did install. I understand you are not eager to buy the Toyota bulbs at $160 each, but there is a big difference between installing a brand-name HID bulb, vs. the cheapest one from China that you can buy on eBay.
    There are many posts that recommend suitable Philips HID bulbs that will turn on and stay on.
    As to the question about why the light does not stay on, this is simple: HID works by a high voltage arc discharge that causes the light emission. The arc discharge can be started at a relatively low voltage. As the light produces heat, the gas pressure within increases and a higher voltage is required to maintain the arc.
    As the bulb wears out, the voltage required to maintain the arc is greater than the ballast can provide, so the light goes out. For safety reasons, the ballast may stop producing voltage after a reasonable number of tries. Then when you turn it off and turn it back on, the arc may resume, temporarily.
    High-intensity discharge lamp - Wikipedia, the free encyclopedia
    fegeg and The Electric Me like this.
  6. The Electric Me
    9,083
    5,801
    Did not realize you had HID headlights.
    You might do a search.
    There are quite a few threads, as if I remember right, Gen 2 Prius did have issues with the HID headlights.
  7. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    HID lights have a "ballast" to fire them, right ?
    That ballast can overheat, trip the internal thermal protection and then re-fire after cooling off.
    The condition you describe is most often caused by a bad ballast.
    Could be a corroded connection too, I guess.
  8. fegeg
    fegeg Junior Member
    Atlanta, GA
    I buy Philips ones from ebay
  9. fegeg
    fegeg Junior Member
    Atlanta, GA
  10. Patrick Wong
    18,210
    6,526
    OK. If you are using this bulb on both sides of the car, and both bulbs continue to be intermittent, then the problem could be the ballast units or the problem could be bad 12V wiring to the ballast units.
    You could try buying one replacement ballast and installing it, to see if that helps. Unfortunately, it is hard to troubleshoot an intermittent problem without substituting parts.
  11. nh7o
    1,686
    340
    Hawaii
  12. fegeg
    fegeg Junior Member
    Atlanta, GA
    I am using these bulbs on both sides, but only one side is intermittent
  13. Patrick Wong
    18,210
    6,526
    You might pull the bulb that is intermittent and see whether it shows any of the characteristics of a fraudulent bulb. The price of $33 including shipping is pretty low for an authentic bulb.
    If you find the bulb to be fraudulent, then buy the correct bulb from a Philips authorized reseller.
    If you find the bulb to be authentic, then you'll have to decide whether you want to buy another bulb or buy a ballast unit.
  14. sambojoho
    sambojoho Proud conservative
    92
    23
    Ohio
  15. fegeg
    fegeg Junior Member
    Atlanta, GA
    sambojoho
    See my link above. Are you saying that the Philips I got is not good and the Philips you've got is better?
    Is there difference in "Philips" bulbs?!
    As I mentioned I replaced the "bad" side bulb already (from Philips to Philips) and it did not help.
    The "good" side stays good.
    Any particular reason you would think replacing the pair would make a difference?
  16. Patrick Wong
    18,210
    6,526
    "Is there difference in "Philips" bulbs?!"
    See post #11 which explains how to determine counterfeit vs. genuine Philips bulbs.
    cwerdna likes this.
  17. fegeg
    fegeg Junior Member
    Atlanta, GA
    Just saw now that #11 is actually a link :)
    Thank you!
    Based on all signs in that article I have genuine Philips bulbs.
    They are not $15, see my link, they are $33 a piece.
  18. nh7o
    1,686
    340
    Hawaii
    OK, perhaps the bulbs are OK. The car having been in an accident would open the possibility that the wires or plugs to the light in question are intermittent. Try turning on the lights and flexing the wires to see if you can duplicate the problem. Wear a glove to be on the safe side. If you don't find anything, then you are left with the swapping parts method.
  19. sambojoho
    92
    23
    Ohio
    Try replacing both bulbs at the same time with Philips. Mine were giving me fits until I replaced both at the same time with Philips. Now been 1.5 years trouble free.
    iPhone ?
  20. Easy Rider
    982
    210
    N. Central Florida
    I'm not a big fan of just taking wild guesses and throwing money away on parts guesses.
    Whatever the voltage is supposed to be at the bulb when running........it should be a fairly simple matter to test for the presence of that voltage, right ??
    If the power is there, then you have a bulb problem.
    If not, the problem is farther back up the line.
    I once again suggest ballast.......because the symptoms you are having matches perfectly an overheating ballast.
