Prius Hitch Mounts Strength
Discussion in 'Gen 3 Prius Technical Discussion' started by andreimontreal, Mar 1, 2020.
  1. andreimontreal
    andreimontreal Active Member
    390
    118
    40
    Montreal
    Been following the talks about towing and hauling with a Prius. Assuming the car has air suspensions to accommodate the extra weight, I wanted to ask those of you who might have an idea (mechanics, engineers) about the following situation.
    Say you have a custom hitch carrier (the load is hauled) and the weight is about 300 lbs, 15-20 inches from the bumper. Is that pressure likely to realistically bend the car's frame (think the worst: pothole, or bumps) assuming the carrier up to the mounting plates is made strong enough with a 2-3x safety factor into the calculations (say two 2" pipes, to take out the possibility of the load torquing the mount left-right too much).
    Do you think it would really ruin the car's handling? The weight in the back creates a lever effect, lifting the front (ever so slightly at least) - I'm wondering how it affects the car's riding. From those who have done it I didn't get any negative feedback; most seem ok with it.
    I've seen this guy with a Corolla carrying a 250 lbs motorcycle and, in spite of the wind drag, he likes the outcome. And this guy with a Gen2 Prius in a similar situation - his mpg is low, things seem to be working great from what I've seen in the video.
    Do you think it's necessary to reinforce the mounting area to support all that weight, or the frame can take it? I've been looking at this guy hacking unibody cars and explaining the build of unibodies and it seems they are stupid tough and have enough folds and cross members in the structure to make it strong. But I could be wrong.
  2. Mendel Leisk
    42,384
    I don't think it'd be realistic or practical to reinforce the body. There are tow hitches designed. They connect at the exhaust bracket on the right side, and at a tow lug on the left side. I think a small, well balanced trailer is best bet. Thought about it a bit, wouldn't do it myself, but others have.
    Tim Jones likes this.
  3. andreimontreal
    390
    118
    40
    Montreal
    Why not? It's a piece of metal. You can weld on it. With a tig welder, nuts/bults, plates cut and bent in certain shapes, square tubing there can be done additional piece to support the leverage. But the question is - how strong is the frame?
    The way it looks, the mounting points are on the rear rails or near those. Which are part of the frame - ie really strong. But I could be wrong, I'm not an expert on the subject. Although, I think, if I were a car engineer I would mount the hitch on the strongest part of the car trying to make it as much "one" with the car (I don't think they would do anything less than that).
    @Raytheeagle - you strike me as a mechanic with all your knowledge (correct me if I'm wrong). Any insight on this?
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I'm a chemical engineer by education, but mechanically inclined;).
    The Prius manual states to not tow with it, so we'll start there as the Toyota engineers warn against it:cool:.
    1. Is anything possible: Yes
    2. Could you make the Prius tow: Yes
    3. Have others added a hitch to their Prius: Yes
    4. Could you do more work to reinforce the area: Sure
    5. What are the effects on the other components as a result of the extra weight added to the rear of the Prius: Not sure
    6. Could you damage something in the process: Possibly
    7. Is it worth the extra effort: Only you can answer that:)
    That's my perspective. If I need to haul something, I usually pony up a small amount of cash that I've saved in fuel and rent a small pickup for the day. Or borrow the neighbors Taco as he doesn't mind (y).
    dig4dirt likes this.
  5. frodoz737
    frodoz737 Top Wrench
    4,812
    2,564
    33
    I won't speak as an Engineer, but as a Licensed Mechanic and owner. Between my last 2010-II and current 2015-4 Prii I have towed more times over more miles than I care to remember...and big loads too. No damage has occured to anything other than MPG. Relax...you are over thinking this. Just mind your fluids better. ;)
    #5 frodoz737, Mar 1, 2020
    PriusCamper likes this.
  6. andreimontreal
    390
    118
    40
    Montreal
    Let me say: I'm a special case that wants to do a crazy solo-travel car conversion out of a Prius (just because). And I'm doing a load of research - both scientifically - trying to scoop out the actual yield strengths and calculating the forces it can withstand (just to get a realistic grasp on the security factor - I'm not crazy enough to dive in blindly) as well as looking at anecdotal information (I actually trust that the machine is made with the same standards of engineering so if it works for another it works for me on that machine).
    I went on this motorcycle forum hoping to discuss with cyclists that have hauled their bikes. I got one. The rest were a bunch of overprotective, abrasive mothers trying to drill me for starting the end of the world as we know it by hauling with my tiny hatch.
    I also went on physics and engineering forums and a lot of people overreacted. Like Vegas RoManiac (the Corolla guy) said when I asked him about people losing their minds when they hear about such projects - "they're all a bunch of idiots". Both me and that dude grew up in East EU and we have seen things growing up, things weren't so strict - and the bottom line is that we learned to use a bit our intuition and gut feeling. Heck, my dad loaded the car so heavily when we went cross country - I must have it from him. My gut feeling says it's more than doable, it's like having a heavy guy riding on a hitch hauler (could a human bend a car jumping on a 20"inch lever sticking out of the hitch? do engineers at Toyo make the cars that fragile? I doubt it), but I wanna get some data down before for a bit of an educated precaution (maybe over-thinking like you say, but I wanna be rather safe than sorry in spite of the mounting real life examples).
    I know people have hauled 250 lbs bikes. I have seen so far both priuses (2nd, 3rd gen, 3rd gen Prius C) hauling 250cc dirt bikes (about 250 lbs). The guy with the 2nd gen above says he gets pretty good mpgs - if I get that I'd be stoked. He got 45 mpg - how much do you get when pulling a trailer?
    #6 andreimontreal, Mar 1, 2020
  7. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Good luck collecting your data and keep us posted(y).
  8. andreimontreal
    390
    118
    40
    Montreal
    I will. I absolutely love the positive attitude on this forum and the dedication. I want to document the process so - when ready - you're all getting updates in the mods thread.
    The camper/travel conversion will be up first. Then I'm gonna gear up to do the hauler (I have this special air piston idea, let's see if I can make it happen) - so that might take up longer to post, 1-2 years maybe.
  9. frodoz737
    4,812
    2,564
    33
    Worst was about 25-26 mph doing 65 mpg front Denver to Dallas (the KS route) with open 6x9 hauling top and bottom roll-away and personal belongings. Use a 1-1/4 Curt Class 1 hitch with 2" ball high offset and harness.
  10. andreimontreal
    390
    118
    40
    Montreal
    Let me post a bunch of other people with their sedans and 250 lbs bikes. For those researching.
    This Subaru WRX dude (double the power of Prius, roughly the same weight class). Def did not adjust his rears - if you have the patience he tells some stories throughout ... too much vlogging in there mixed up.
    This custom job with a Mercury Sable ... looks like he created some additional attachments to take out some of that torque in the car's rail. The carrier is custom.
  11. andreimontreal
    390
    118
    40
    Montreal
    Gonna do a custom mount with 2 pipes; gonna have to calculate but 1.25" off the top of my head. The idea is to have the support in the corners to take out the moment/sway of the carrier (whatever the load). The 2nd thing is that I want to fit a parallelogram lift underneath that would lift via air pistons fed by the same ViaAir compressor that would feed my rear suspension air support. So: the forks/loading bin/tray would be on the ground and away from the trunk when loading and sung against the car when up because the parallelogram would close by pulling towards the car (the bottom, aka the forks, would side under the car - tell me it doesn't seem like I felt a bit on my head once or twice).
    I'm also considering getting a rear fender, paint it with my quality gun, do cutaways so the pipes would sit flush sticking through the fender (I don't wanna ruin the oem one); also bending the pipes slightly upwards to get more ground clearance. Again: my measurements are very very rough at this point. Still have to test with wood mockups, do do calculations to see exactly what it takes to build this.
    Yeah, this is gonna take $. But I hope it will work great and it will serve me for many years to come. Plus all the experience that I'm getting out of it and the knowledge/skill that I'm acquiring
  12. PriusCamper
    PriusCamper Senior Member
    13,479
    5,446
    Pacific Northwest, USA
    I bent my Curt 1-1/4" hitch... The receiver used to almost touch the black trim at the bottom of the bumper cover and now there's a 3/4" inch gap. It happened because I needed to haul my wheelbarrow size wood chipper ~250 pounds on a round trip of 1,600 miles and didn't want to dismantle and put inside the car like I usually do because I needed that space for sleeping.
    And because most hitch mounts stick out too far (longer lever = more force) I built a custom mount for my chipper that was as short as possible and dismantled and removed as much of the weight of the chipper as possible and mounted it so close to the rear bumper cover that I used some wet sponges to limit movement / prevent scratching and the whole thing was wrapped in a tarp, so it was a solid covered extension of the rear of the car so their was no noticeable loss in MPG. It did handle more sloppy, but I drive a Prius so it's all about driving slow and getting good MPG anyways so anything to encourage me to drive slower is great as far as I'm concerned!
    Everything was going really well and no issues, then I got to the worst part of the drive on the 880 in SF Bay Area where people drive like lunatics on crazy worn out roads. There was a section that just to merge in the "slow" lanes you had to be going 75mph and that's when I hit a major slump in the road I knew that was going to be the max force on what I built. And sure enough the hitch bent... It still works fine and no signs of damage to the vehicle where it mounts or elsewhere. I tried jacking the car up from the hitch receiver to try to bend it back, but there's no way I could come near the force that bent it down in the first place and even if I could, it's would weaken the metal even more.
    So if I were you, I'd find a way to rapidly dismantle the motorcycle so you keep the load of the tongue weight down and then I'd build an aerodynamic structure that the hypermile max-MPG folks use which will give you more room to store lighter stuff in the far back and hopefully find a to modify your rear hatch so you can get the majority of the motorcycles weight over the rear wheels of the car rather than hanging off the edge in a way that will bend your hitch, or cause unpredictable handling if you're ever trying to avoid getting in an accident at freeway speeds. That way you also don't have to waste a fortune of money and dozen of hours re-designing the suspension or reinforcing the hitch...
  13. frodoz737
    4,812
    2,564
    33
    My Son hauled his Harley twice using the 2015-4 with the Curt 1-1/4 set up no problem. YMMV
  14. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    A really important point that may explain some of the reactions that you may see as being overly cautious:
    If you don't know what you're doing when you try BASE jumping, well, that could be a problem for you.
    If you don't know what you're doing when doing something like this, that could really ruin someone else's day or life.
    May be better to let the more knowledgeable people blaze the trail and follow them, if you really want to do something out of the ordinary. Many of your basic comments on this are fundamentally wrong and I don't think you know. This project is not a place to learn that.
    Good luck and keep everyone safe.
  15. PriusCamper
    13,479
    5,446
    I disagree... I think the OP's approach is both thoughtful and thorough and way safer than many others who would attempt this. And I find your comments provide no specific details whatsoever, just a bunch of sweeping overgeneralizations hyping up the fear via false equivalencies.
  16. 2012 Prius v wagon 3
    281
    278
    I will agree with that one.^^^
    That does not mean it will be safe enough to be driven in front of you or me.
    I'm trying to be as diplomatic about this as I can, so yes, I'm speaking kind of non-specifically.
    If you look at some people's posts on here, you will see a lot of enthusiasm and very little skill, knowledge, experience, or good results. That's just fine for upgrading interior lighting, putting on bumper stickers, converting the car to cold fusion power, or adding a nitrous kit. Nobody ELSE is going to get killed if those projects fail. The project discussed here is completely different. It becomes a danger to innocent people driving down the road, minding their own business, wearing their seatbelts, just trying to safely get where they need to go.
    As a different example, again, trying to be nice, if somebody led a 10 page thread of bewilderment about the difficulties they were having in doing an oil change or filling the gas tank ... then proposed a plan to make the back half of the car easily removable from the front, for ease of loading ... but they were really serious about it, what would you think? (yes, greatly exaggerated hyperbolic scenario to make my point)
    Here's a specific one, guessing at the design engineers' intentions: "Although, I think, if I were a car engineer I would mount the hitch on the strongest part of the car trying to make it as much "one" with the car (I don't think they would do anything less than that)."
    The "car engineers" don't design a Prius to carry a hitch as a prime directive. Or even an afterthought. Toyota knows people will try anything, but recommend not to install a tow hitch. They design the car as efficiently as they can to do what it has to do.
    Trucks and SUVs are designed differently, and will have strengthened structural members with hitch mounting locations designed in place. Even my mini-vans have had that. I have 3 degrees in mechanical engineering and would never consider home brewing a tow hitch, even for use on a vehicle with designed mounting points. Sure, I might see things differently if I lived in a post-apocalyptic Mad Max world where the other dangers of the world outweighed that from a failing hitch.
    And BTW, I absolutely love crazy ambitious stuff like that Prius longtail photo above. But things like that (yes, it is putting innocent people at risk, if something were to fall off) need to be done by competent people, where their enthusiasm does not outrun their capabilities.
    #16 2012 Prius v wagon 3, Mar 2, 2020
  17. PriusCamper
    13,479
    5,446
    There's plenty of evidence of idiots, especially pickup truck drivers, who don't properly secure their load... There's also plenty of evidence of people who modify their vehicle in a way that puts other people's lives in danger.
    But I'm not seeing much evidence at all of people who spend a long time researching and discussing car hauling modifications losing their load or putting other people's lives in danger.
    I spent over a dozen hours researching & designing a way to haul my 250 pound wood chipper on a 1600 mile trip and I put so much effort into it because I don't want anyone to get hurt and if it damaged my Prius I likely couldn't afford to get my car fixed.
    So the more people I could talk to about what I was rigging up, as well as the more I tested and redesigned to improve strength of it, the better off I and everyone else sharing the road with me was...
    By providing information and assistance to the OP of this thread, I'm hopefully helping make their rig safer. That's not what you're doing. You're just telling them not to do it, which doesn't make what they're going to do safer.
  18. 2012 Prius v wagon 3
    281
    278
    You're not looking very hard then.
    Here's one of the two videos I looked at. The most shocking thing is how unconcerned he is.
    If the kids in your local high school had some ideas about using Propane tanks in lieu of fireworks for Independence Day celebrations, would you try to give them constructive advice on how to do it, or maybe just advise against it?
  19. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    In the UK, the current Prius is rated to tow up to 725 kg. When Toyota GB issued their press release on this, it read in part:
    "Prius's new-found ability is thanks to heat management measures that have been introduced in the hybrid system's main electric motor-generator and the differential. As a result, the car has a maximum towing capacity of 725kg for both braked and unbraked trailers."
    No mention of frame strength; I suspect it's a non-issue, but if you're really worried you can draw the FBD, write up your equations of equilibrium and solve for the forces at the attachment points.
  20. frodoz737
    4,812
    2,564
    33
    To be clear... you can screw the puuch with a semi if you don't know what you are doing. If you have not "learned" how to tow/haul, you probably don't want to learn with a Prius...which IS documented as acceptable by the mfg in other Countries.
