Prius HUD
Discussion in 'Gen 3 Prius Main Forum' started by Tideland Prius, Feb 13, 2009.
  1. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    Or check out versions of the Prius in other countries, like the UK...
  2. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    The reason it's not in Prius in the US is that may detract from Lexus sales, don't you think. I'd bet lunch it can be put in the US,be surprised if there were much to it actually, but maybe a new dash ?$$
  3. antiflash
    antiflash New Member
    93
    47
    Port Hueneme, CA
    i guess there are a few logical starting points for a potential mod - we need part numbers and electrical diagrams. Anyone have a maint manual or schematics for the euro or japan prius?
  4. RoyalBlue
    RoyalBlue New Member
    66
    Groningen - Netherlands
    Good luck if you want to take out the dashboard, make a big hole in it and then install the HUD projector.
  5. TKY
    TKY Member
    232
    25
    Colorado
    Ditto: That's good because it is too true. --TK
  6. a64pilot
    771
    62
    Albany Ga.
    It may not be that big of a thing to do, I wouldn't be surprised if the projector isn't already there as the non HUD Prius image is projected, just not on the dash. Never having seen a HUD Prius, I could be completely wrong though:confused:
  7. a64pilot
    771
    62
    Albany Ga.
    Will you take some pics as to what the dash even looks like for us uninformed?
  8. RoyalBlue
    66
    I can try to do that, but I have to take the picture trough the windscreen. I hope it works.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Not a chance. The non HUD display is not really projected, but simply reflected. The HUD uses a whole different system.
    Tom
  10. SR1227
    SR1227 New Member
    Redondo Beach, CA
  11. Rainingblood
    Rainingblood Junior Member
    35
    Italy
    maybe you can buy the aftermarket HUD from european or japanese dealer...
  12. a64pilot
    771
    62
    Albany Ga.
    Oh well worth a shot, still maybe it would be a "plug in mod" + of course a hole in the dash
    One can only hope
  13. RoyalBlue
    66
    Her is a picture of the HUD, taken through the frontscreen.
    2 people like this.
  14. iota
    iota New Member
    Columbus, OH
    Anyone had any luck sourcing part numbers, etc for this? Hopefully, it's just a "plug in to the unused harness" type mod...
  15. Tideland Prius
    16,680
    You need to cut a hole in the dash too.
  16. tjp74
    tjp74 New Member
    92
    31
    Bothell, WA
    Cutting a hole might not be the most difficult thing to do. It's proably the wiring. You also need this HUD control switches next clock adjuster switch. For that, you also need the trim panel.
    I was going to browse the electronic parts catalogue at Toyota Service Information but I need a VIN or license plate number of the actual car that was equipped with the HUD from the factory. If I enter my VIN, it only shows parts applicapable to my US model. But odly enough, it did show the switch with parts number and when searched it on parts.com, it showed up as available.
    8497547050 SWITCH TRIP $69.53
    Can a european member with prius equipped with HUD share the VIN (Vehicle Identification Number)? with this I should be able to pull parts number of everything needed to retrofit this. If it's possible at all. It cost about $5 to use toyota europe tech info site for about an hour. Database contains all US models as well.
      File size:
      4.5 KB
      1,522
  17. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    You'll rarely find an "unused harness" in a vehicle where an entire region doesn't receive a feature. Even between Prius IV and V, we're missing some wiring for height sensor (LED headlight) and fogs.
  18. iota
    iota New Member
    Columbus, OH
    True, but wiring and harnesses are cheap to make; as long as the programming is in the controller for the MID/digital dash/etc, then we should be able to make the wiring ourselves...
  19. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    see your private message folder.
  20. xyes
    xyes Hybrid Synergy Driver Malaysia
    42
    PJ.my ⇄ N.Borneo
    has anyone successfully connected the HUD to the Navi?
    I've an aftermarket head unit that supports CANBUS, but not sure how it'd connect to the HUD to show navigational direction.
    p.s. I've changed the trip switch to have the NAVI switch too.
