Prius HV Battery High Resistance - Discussion
Discussion in 'Gen 3 Prius Technical Discussion' started by Shady551122, Sep 20, 2022.
  1. Shady551122
    Shady551122 New Member
    Jordan
    Hello Friends
    I have a 2010 Prius , the HV battery had some issues and i replaced 4 cells in it , while monitoring the battery I found out that block 5 resistance is higher than the remaining blocks ( for Example Block 5 is 28milliohm while all the remaining blocks are in the range of 22-23 milliohm using Dr.prius App and these values reach the 34 milliohm for block 5 while the remaining block never exceeds the 28milliohm value) i thought there is an issue with the cells it self since i already cleaned the busbars properly , so i changed the cell with different ones however the values for the same block are still higher than the remaining blocks , thus i changed the position of 2 blocks (block 5 and 6) to check the issue however even after the changing block 5 still reads the highest values (Cells in Block 6 was 22 milliohm before the change and it reached 29 milliohm after i installed them on block 5) so i was wondering what might be the causes for the high resistance values only on block 5 ? how does the system read the milliohm values ? and what can i do to rectify this issue ?
    thank you in advance
  2. ChapmanF
    18,986
    It computes the block's internal resistance by observing the block's voltage when no current is flowing, and then observing how much that voltage drops when a known current flows. The voltage drop divided by the current is the resistance. By looking at the voltage drop as soon as practical after the no-current voltage, the ECU tries to get just the drop due to internal resistance, and not due to discharge of the block.
  3. Shady551122
    Jordan
    thank you for these information's , so it detects the internal resistance when i start accelerating the car right ? and does it keep detecting it regularly ? or only one time ?
  4. ChapmanF
    18,986
    My assumption is that it updates the values regularly while driving. But the battery ECU firmware is not published.
