Prius II HIV battery module change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by flyingstoo, Oct 29, 2012.
  1. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The vents that allow the battery to dry out can clearly be seen in the picture kindly provided by Usnavystgc They are connected together by the black tubes.
  2. Britprius
    5,194
    1,922
    By the way Stu the cells are filled with a strong alkali (KOH) not acid. It is basically caustic soda.
  3. flyingstoo
    flyingstoo Junior Member
    Prestwood bucks,UK
    Just to clarify are you quoting the 'cell' voltage or 'module' voltage. I assume 'cell' as each cell is nominally 1.2v or have I misunderstood something. I am also concerned a little that going below a module voltage of 7.2v would possibly cause damage, sorry if I am missing the point here somewhere.
  4. flyingstoo
    Prestwood bucks,UK
    These vents are obviously not just holes as I would assume that any gas would vent very quickly without creating the possibility of swelling. Any info on how they vent without loosing the fluids ?
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    Do not assume this. Gas will not vent quickly and swelling will def occur if not charged under compression and cooled. If the modules vent, they will also lose fluid. The vents will pass fluid and gas. You don't want them to swell or vent. Venting causes a loss of capacity and corrosion. From what I've read/researched, it takes an extremely high pressure to cause them to vent (that's why they swell).
  6. Britprius
    5,194
    1,922
    Sorry I could have made it more clear, the voltage quoted is cell voltage not module voltage. So minimum module voltage would be 5.1v.
    If the vents do vent the gasses given off are hydrogen and oxygen (water) this is how the cells dry out. Remember in use the battery can be subject to charge and discharge rates in the region of 80 to 100 amps. The venting may not be large amounts but over time non the less drying out does happen.
  7. flyingstoo
    Prestwood bucks,UK
    Thanks John
    So it is not a problem to discharge a module to less than 7.2v (6 x 1.2)...that's news. I was thinking that reducing a cell voltage to less than the 1.2v may lead to problems. However I trust your knowledge on this . I have now ordered my Supermate DC6 and in the meantime I am using a Hitec nimh charger to experiment with a spare module. Don't worry it's clamped in a vice and am charging it up at 1A to see what capacity it can hold. The Hitec charger has an intelligent current monitor that detects full charge and shuts it off when full. I also have an Astro Flight power monitoring device , left over from my aero modelling days, that is proving very useful for recording the AH used.
    Rgds Stu
  8. flyingstoo
    Prestwood bucks,UK
    Thanks for that, I am being very cautious about this. Fortunately it's winter and my garage is flipping cold!....which helps with the cooling
    usnavystgc likes this.
  9. Britprius
    5,194
    1,922
    Sounds like you have everything tide up.
    The DC6 charger has the same function as the Hitec and detects the so called nee of the charging curve then shuts off the charge lets the battery rest then discharges it lets it rest the recharges and does this for the number of chosen cycles.
    Keep everything you do logged numbering each module and marking with the final capacity. As I said before takes time but is worth the effort. Any questions I will answer if I can and I'm sure other people will help if I cannot. Best of luck.
    John (Britprius).
  10. flyingstoo
    Prestwood bucks,UK
    Hi John
    I have got my dc6 and have started the process of cycling the modules. I have not noticed any problems with module heating at all which makes me wonder if I am being too conservative with my charging parameters. I have charged up to a 6450 mah limit and taken the module down to a 5.7v min limit. The first module took in the full charge on all 3 charges and on each discharge put out the following mah. 4334mah,5091mah,5220mah.
    This shows an increasing discharge capacity on each cycle but I wonder if I should be pushing the module harder with a charge load of 6700mah and a lower discharge cutoff voltage?.
    The maximum discharge current of the dc6 is very low ,only .7A which means it takes ages to discharge. I presume this is because the charger has a rather low wattage load resistor circuit. There isn't a method of upping this rate by utilising an external load in parallel is there?
    The maximum temperature I ever measured on the module case was only 15c. With module firmly clamped.
  11. Flying White Dutchman
    4,376
    313
    best to buy a powerlab charger/discharger.
    looking at your dealer price for replacing these ~200 dollars devices can help a lot
    they can be connected with a USB adapter and so on your PC you can see a graph and a capacity calculation.
    this way you can match cells and find the failty one with far less cap.
  12. Britprius
    5,194
    1,922
    Hi Stu, I would go with a slightly higher charge limit of say 6750mah.
    The modules should start to warm up when the charge capacity limit has bean reached. This is because the good cells in the module cannot absorb any more charge so that any current through them is given off as heat, it is this stage that allows cells with a lower charge to catch up and become fully charged, thus balancing the cells in that module.
    You are obviously going in the right direction as the modules are shown to be improving in capacity, close to 1 amp/hr. I do not see anything to gain by discharging further than the present limit although this may show up as more capacity it also runs the risk of reverse charging any low charge cells within a module. It is the top of the charge cycle that gives these cells the chance to catch up.
    The problem you have with the discharge rates is well know and as you say it is governed by the discharge resistors within the charger. I did not have the problem as I had 10 chargers "bought in an auction of bankrupt stock probably for little more than you paid for one charger" speeding things up dramatically. It may be possible to add external resistors but not having a charger now I cannot look into this, but I did warn you it took time and patience to balance a complete pack.
    Hope this is of help and not disheartening.
    John (Britprius)
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    Stu,
    Yes it is painfully slow. Adding a larger load to the battery will discharge it faster but, I don't think your charger would be able to measure the capacity accurately. You could easily put a 6v lightbulb in parallel w/ the charger. This would discharge it faster but, you would likely get a lower ah reading from the charger. I'm thinking if I was in your shoes, I would charge/disch w/ charger only (for baseline), charge/disch w/ charger and light, and charge/disch w/ charger only to get a final reading. This would speed it up a little.
    Alternatively, you could do all 3 cycles w/ the light and simply match cells to those readings (knowing the capacity is actually higher).
    What do you think John?
  14. Britprius
    5,194
    1,922
    The idea in its self is sound.
    The problem is that the charger is programmed to do the charge/discharge cycles unattended making it difficult to know when to attach extra load for discharging.
    Unless all modules are treated and balanced in the same manner the amp/hr readings become meaningless. In other words the load needs to be switched on and off by the charger. This may be possible just by bridging the internal resistors as long as the path for the current through these does not run through any solid state components (transistors diodes ect) that cannot handle the extra load.
  15. flyingstoo
    Prestwood bucks,UK
    Hi John
    I have come up with a 'cunning plan'....by using my astro flite charge/ discharge device and a 6 ohm 20 w power resistor (suitably heatsinked in a metal vice) I can parallel discharge the module whilst the dc6 is also discharging it.this improves the discharge current to 2 amps. Before discharge is complete I disconnect my Astro load device
    Adding the AH readings from dc6 and astro device gives me total discharge AH.
    The only thing is that i don't have a way of offloading the Astro load automatically so I have to set an alarm and go out to the garage to check the voltage states. I hope though to rig up an auto timer when time permits.
    I am still not seeing much heat from the module with this setup and am now charging to full 6750 mah
  16. Britprius
    5,194
    1,922
    Sounds good as long as the treatment is exactly the same for all modules, otherwise the figures will be meaningless.
    Do not worry about the amount of heat you are noticing the important thing is that you see improvement in the amp/hr capacity of the modules as you slightly over charge them.
    The heating wattage would be .7 amp (your charge current) x about 8.5 volts the end voltage charge (may be higher than this), about 6watts spread over the module, but you can get into a situation of thermal runaway when charging so do not try to push things in this area.
    Keep up the good work I know it can be tedious but worth the effort
    PS. what area are you in the UK.
    John (Britprius)
  17. flyingstoo
    Prestwood bucks,UK
    Hi all
    It's now late May and I finally finished the module balancing procedure in mid January. The voltages and charges looked very well balanced from the data extracted from the charger, I connected the modules in a parallel circuit and left them for a day to hopefully improve the balance. This seemed to not cause any problems, I then reassembled the unit and checked all module voltages.
    Due to weather and other commitments I have not been able to reinstall and test the unit until yesterday. The installation went okay and the car appeared to be fully operational. The car went for 25miles and drove normally with all indications that the battery was functioning okay. Then however when pulling away from traffic lights the dreaded warning triangle and associated amber lights came on. On return home I put the torque app analyser on the car and it showed the P0AFA power train error. I couldn't get the deeper codes but using the HV module voltage function in graph mode showed that module 01 was oscillating in voltage from 15 v down to readings as low as -10v. I think that the -10v value is probably an overshoot but the indications are a bit odd. The sampling rate of the app may not be quick enough to accurately show what's happening so I monitored the module using a meter. I could not see this variation and the voltage seemed to be stable at 15v.
    I was not 100% sure which end is module 01 so I checked both ends.....is module 01 at the ebc computer end?
    Anyhow, I am now wondering where to go with this and am considering whether to sell this unit for spares......any ideas?
    Brgds Stu
  18. bwilson4web
    16,442
    I'm wondering if the sense wire might be loose or making intermittent contact. The KOH electrolyte 'eats copper' and I've seen photos of one sense wire that 'looked OK' but it was just the insulation. The copper inside the sense wire had been corroded away by the KOH.
  19. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes, I agree with Bob. The most likely cause of this problem is the sense wire. You proved beyond a doubt that the module was stable . The symptoms you describe I've never seen a battery vary in voltage by that much not to mention that quickly. So in essence, the module is not the problem. Your sense wire is either loose or corroded away. This is an easy, cheap fix.
    I don't recommend you use/sell this unit for spares because you will have the same problem with a new pack.
  20. flyingstoo
    Prestwood bucks,UK
    Thanks for the ideas, I also did consider this and removed the battery ecu and plugs . The sense wires all checked okay and I even took out the ecu and checked that the connections are sound inside. Could it be that under load the module is unstable?
    The problem is that I need the car so can only swap batteries over when time permits. I did wonder if the ecu has a fault but I don't fancy taking one out of my working battery in case it gets damaged somehow....
    I may try moving the suspect module and see if the fault moves with it.
    Brgds Stu
    bwilson4web likes this.
