Prius II,III,IV vs. V Fuel Economy
Discussion in 'Gen 3 Prius Fuel Economy' started by joe480, Nov 10, 2010.
  1. Dr.Mikki
    Dr.Mikki New Member
    29
    Helsinki, Finland
    The honest answer is that I just know this because I live EU :D. The official test data is the only thing the car manufacturers are allowed to quote. Here are the UK numbers (the site does not mention the tire size so you just have to take my word for it, or look it up):
    17" Prius (T4)
    VCAcarfueldata.org.uk - Search Results - Further Information
    15" Prius (T3)
    PS I would save 1.82€ per year if I would change my tires from 17" to 15"... aint gone happen :cool:
  2. geminikanon
    geminikanon New Member
    26
    South Bay
    I just swapped my stock tires for the 2010 Prius II to 17" rims. In the past, I was able to pull off around 54mpg with stock tires, but now I can barely hit 47. This drop seems significant.
    So, according to many postings on the thread, I should expect around 2~3 mpg drop going from 15" to 17". I don't know there the other 5mpg goes.
    Just wondering, does anyone know whether ambient temperature affects mpg? The only thing different aside from swapping the wheels is that the weather got a lot colder in CA since I got my Prius in March.
  3. joe480
    joe480 New Member
    michigan
    Sweet! A database like this is what I was hoping for. Thanks!
  4. Tideland Prius
    16,547
    Oh it definitely affects mpg. All vehicles get worse mpg in the winter from a combination of things
    1. Winter fuel blend (more additives, less petrol)
    2. Colder air (longer engine warm up time plus cold air being drawn into the engine bay... I don't think air density plays a role but maybe it does when you get to -40 compared to 86?)
    3. Heater usage
    4. Winter tyres
    5. lower tyre pressure (one reason why you need to check your pressures regularly and pump them back up)
  5. geminikanon
    26
    South Bay
    Thanks for the insightful reply. The temperature here in the SF bay area dropped from around 70~80 to around 40~50 in just 2 weeks. I do not turn on the heaters nor do I put on winter tires. For tire pressure, I check regularly and is at recommended levels. So, with that said, I lost 5mpg due to winter fuel blend and temperature drop? Is this what other people on this forum typically experienced with temperature drop?
    I'm asking because:
    1) I ordered pre-mounted and balanced wheels from wheelsnext.com. I don't know if they did a good job mounting/balancing the wheels ...
    2) I just went to the dealer service for my maintenance, and I asked them to install my new wheels and replaced engine oil. Hope they didn't do anything to screw up my mpg ...
    I've enjoyed a steady 52~54mpg so far, it's a bit hard to live with < 46~48mpg now ... I'm sure many Prius owners can understand =D
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Also from the SF Bay Area - I saw a 4 to 5 MPG drop in my last two tanks that I attributed to the Winter fuel blend.
  7. geminikanon
    26
    South Bay
    Thanks for the reply. Oh wow. I guess I should be relieved that it wasn't some mechanical mishap. But 5 mpg drop due to winter fuel blend ... who'd ever thought it would be this significant?
    I wonder, does the EPA ratings come with the disclaimer that the 51mpg for Prius is characterized with none-winter blend? I can imaging people who bought Prii at northern states during winter cratching their heads wondering why their mpg is at 45 when EPA rated it at around 50.
  8. Tideland Prius
    16,547
    You lose a few mpg due to 10% ethanol blend so winter fuel blend (do not know the exact mixture) causing a 5mpg drop seem reasonable but I'm sure the temperature played a part. Not all 5 mpg is due to fuel changes.
    It's hard for us to maintain 55mpg up here (my worse tank last winter was into the mid 30s thanks to a week of extreme cold). The cold temps have been delayed a bit here so I'm still enjoy a 55mpg tank so far (daytime highs have been above zero) but I know it's not gonna last forever...
  9. joe480
    joe480 New Member
    michigan
  10. Becual
    Becual New Member
    Leesburg V.A
    Why would there be Higher MPG when the car is hot. And what's the deal about blocking the grill?
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    1. Internal combustion engines are more efficient at normal operating temperatures and above than below.
    2. Partially blocking the grill speeds engine warm up and improves aerodynamics.
  12. Tideland Prius
    16,547
    The reasons are because an engine that is fully warmed up (i.e. running at operating temperature) is running at its best efficiency (under normal load that is) and using as much fuel as it was designed to do. A cold engine needs to burn more fuel (thus increasing fuel consumption) to help generate heat to warm up faster as well as generate hotter exhaust gas to warm up the catalytic converter (a warm cat converter means lower emissions).
    This is why people living in colder climates are advised to get an engine block heater. This allows the owner to pre-heat the engine, allowing for a shorter warm-up time and helps get the engine up to operating temperature faster.
    Unique to the Prius (and other hybrids) is that once the engine is warmed up, it can shut off, allowing you to glide or drive with the battery, thus further saving fuel.
    Blocking the grille helps lower the cooling effects of air flowing into the engine compartment, again helping the engine warm faster. Just imagine having the heater blow in your face but you have the roof lowered in a convertible. You're not going to get as warm than if you had the heater going but the roof up and the windows closed.
  13. Mendel Leisk
    41,315
    Another possible factor: the 17" tires rotate about 2% more revolutions in any given distance. The OD's a little smaller.
  14. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Toyota doesn't distinguish between models for MPG purposes in the US. Toyota UK released a doc that does (try a search--this topic has been discussed a bunch ;)), and from memory, the 17" wheel model had ~2% lower MPG--a rounding error.
  15. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Colder temps take a huge toll on mpg. My 2000 Insight 5 spd could do 70 mpg easily May to Sept and drop to high 50's for the winter. Giving a Lifetime mpg of 62 for 265,000 miles. The 2010 Prius II gives me a solid 60 avg May to Sept, but is already down to 55 mpg in November and I have not even put the snow tires on yet. I expect low 50's avg for the winter, giving a likely 55 mpg lifetime. Between cold starts, m.ore tire resistance from the snow tires, plowing thru snow and slush, more heater use, etc - its a big mpg hit.
  16. Sassan
    Sassan New Member
    33
    Troy, MI
    My V has dropped from 57mpg to about 52.5 as the weather has gotten colder. My drive home still is around 55F, but the closer that gets down to the 30-40F range, I think the lower it will get. I'm going to guess lowest it will get this winter would be 50-51.
  17. ggcc
    ggcc Member
    132
    Bay Area, CA
    2014 Prius Plug-in
    I agree with this. To save the cost, I think the Prius o meters in type II and V are the same. That is the reason why type V Prius (17 inch rim) owners see lower in mpg but actually they are the same mpg.
  18. fuzzy1
    10,406
    If tire diameter / odo cal was the real reason for a difference, V owners would be computing higher MPG because their odos would be reading 2% higher than actual distance.
    Actually, this cannot be true. Some auto makers (e.g. Honda and Subaru) have been hit with class action lawsuits about warranty fraud because their odometers read too high. The settlements made allowance for 2% error. Any car maker that designs in this problem post-Honda-lawsuit is an idiot.
  19. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  20. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    That sounds about right.
    There was a very old thread from around the introduction or when the 2010s first shipped which explained why you couldn't get the solar roof w/Prius V (has 17" wheels) due to additional weight. Essentially (IIRC) it would've forced Toyota to have publish different mileages for the US for 17" wheel vs. non-17" wheel versions.
    edit: The above has been discussed/debated a lot in the past. http://priuschat.com/forums/gen-iii...prius-option-packages-naias-5.html#post786779 was an official answer from Toyota.
