Prius III sunroof sounds
Discussion in 'Gen 3 Prius Main Forum' started by H.S., Mar 26, 2021.
  1. H.S.
    H.S. Member
    118
    26
    Venice, ca
    Hello
    I have a 2015 prius 3 with the solar roof. I have been noticing alot lately how noisy it is when i have it open and loud squeak it makes as I drive through inner streets. anyone experienced that problem? any recommendations? thank you
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    never, I use lithium lube on them twice a year because it gets open and closed a lot.
  3. ASRDogman
    ASRDogman Senior Member
    8,058
    4,085
    Close it. :)
    #3 ASRDogman, Mar 26, 2021
  4. Rocky Mountain Priusman
    Rocky Mountain Priusman Active Member
    224
    112
    Canmore, Alberta, Canada
    So far no noise from my newly aqured 2010 prius with solar roof and sunroof. I've only driven it about 400 miles though...
  5. H.S.
    H.S. Member
    118
    26
    Venice, ca
    mine is close to 95K but not sure whats causing the noise or something needs oiling? or changed?
