Prius immediately shifts into 2nd gear at takeoff
Discussion in 'Gen 2 Prius Technical Discussion' started by Nelflez, Sep 19, 2023.
  1. Nelflez
    Nelflez New Member
    Colorado
    After driving my 2006 Prius for around 50k miles I've learned a lot about it. I'm a fast driver and love to get up to speed quick and in doing so I've learned how to get my car up to speed as fast as it possibly can. The fastest I've gotten on a 0-60mph is 6.5 seconds in 60° degree weather (AKA what I've found to be the perfect temp for performance). Hot weather kills its performance if that hasn't been noted before. But not bad for a stock Prius.
    But I've learned that flooring it from takeoff immediately causes it to shift into second gear and have an unbearably slow acceleration. So I've learned to quickly hit the pedal half way down and once you hit 27mph-35mph then you stomp it, and I'll tell you, if you want to have at least some fun with it, this is most definitely the way to go.
    But I'm here to ask, why does it go into second gear from takeoff? And is there a way to "fix" that? Or is it just how the car is?
    And just to clarify, I know it's dumb to floor is around all the time. But honestly I've had more than a lot of fun with it and have had people ask me if it's modded hahaha. A lot of people are respectful to me on the roads or if they're behind me at a stoplight if they recognize me cause they know I don't drive slow. I also got a sticker that says "Fight For Prius Equality" on the back and people seemed to actually get a laugh out of that. I love my little Prius, I will be more than sad once it dies. As of now I'm pushing 250k miles.
    SFO likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    You do realize the transmission is of the CVT design and you know what that kind of means? There's always that second gear takeoffs absolutely. Sounds like you've mastered the Prius with your quick wonderful takeoffs what is your gas mileage averaging now I'm sure that doesn't matter to you probably. Just imagine what a Corolla would do or a 1JZ car at 250k you are just at the halfway mark of your car's usable life.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    There is no second gear in a Prius. Or first, or third. Take a look.
    52,891
    Probably a loose vacuum hose on the tranny
  5. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    If you haven't already, best to balance the HV battery with gridcharger / dischager, either DIY or from a known retailer.
    Finally something that may help my prius find the "privilege" it deserves :ROFLMAO:
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I think the system design "logic" might be causing it to run on the ICE alone with little to no
    help from the battery when flooring the pedal from a standing start.
    Just a guess.
  7. pasadena_commut
    pasadena_commut Senior Member
    3,071
    956
    Southern California
    If the pack is acting up I believe it can dial down the electric assist to nothing, but you should be seeing codes at that point.
  8. Nelflez
    Nelflez New Member
    Colorado
    My average mpg is a beautiful 37.1mpg. If I drive it kindly I can get 42mpg lol
  9. Nelflez
    Nelflez New Member
    Colorado
    I'm glad you like the sticker hahaha, you can order custom ones off amazon for like $10. But also what would charging the battery manually do?
  10. pasadena_commut
    3,071
    956
    Southern California
    Puttering around in ours in suburban traffic we see around 45, and it does a solid 49-50 on the open highway. But the OP is in Colorado, and might be seeing substantial elevation changes, or running at a much higher elevation, both of which can reduce efficiency. So maybe beauty is in the eye of the beholder.
  11. netsplit
    netsplit Junior Member
    48
    16
    Earth
    It reconditions it and re balances it
