Prius Immobilizer
Discussion in 'Gen 3 Prius Audio and Electronics' started by aspacardin, Apr 21, 2015.
  1. aspacardin
    aspacardin New Member
    Greece
    I need to install a gps monitoring system on a prius (and some other pure electric cars) used for rentals. We also need to be able to do remote immobilizing of the car. On our gas powered cars, we normally install the immobilizer on the engine starter, so there are no safety concerns while there's someone driving the car. Where could we install the immobilizer on the prius, so that if something goes wrong with our gps device, the car still works if there is someone driving it, but it can not be restarted once it stops?
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you disable the brake switch, a Prius cannot be put into "Ready" mode after it is turned off.
    JeffD
  3. fuzzy1
    10,706
    Is that the same switch that triggers the brake lights? That sounds like a road hazard. This would be safe only if the ignition interlock uses a separate brake switch.
  4. qdllc
    qdllc Senior Member
    1,377
    400
    If the immobilizer has a fail-proof "logic" circuit, you could use the brake switch. Meaning, if you activate it, it won't engage until the power to the car cuts off, then depressing the brake won't work. No danger of cutting off someone's brakes while operating the car.
    Have you chatted with Toyota on this? I'm sure their anti-theft features may already do this and only need to interface with the immobilizer device.
  5. fuzzy1
    10,706
    It isn't the brake function I'm concerned about, the switch won't disable that.
    But the brake lights are a required safety function to warn the driver behind that the brakes are being applied. The switch that operates those warning lights cannot legally be disabled. Does the ignition interlock use this same switch, or a separate switch?
  6. qdllc
    qdllc Senior Member
    1,377
    400
    I'd have to see a wiring diagram. If the brake pedal energizes two circuits (one for lights, one to tell the computer the brake is applied), you'd only need to disable one of them. If the computer uses the brake light wire to determine if the brakes are applied, yeah, that'd be an issue.
  7. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I can send the OP the wiring diagram for a Gen2 if it helps. It is large (6.5 Mbytes) so he would have to PM me his email address. I do not have Gen3 documentation.
    JeffD
  8. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    It's possible. The manual I have seems to show that the stop light switch is a DPST switch with one normally-open and one normally-closed. The normally-open side looks to be connected to the battery more-or-less-directly, while the normally-closed side looks like it might only be connected to the battery when the ignition is on. It's hard to tell though, because the information is split between multiple diagrams (and which side is normally-open changes between them).
    Looking at it more, it seems like the normally-open side is used both for the Power Management Control ECU (which I assume is responsible for starting the car when you press the power button) and the stop lights, while the other side is probably to detect a failure in the stop light switch (which would cancel cruise control, illuminate the CEL, and who knows what else).
    So the way to do it would probably be to insert it as close to the power management control ECU as possible; the other ECUs and the brake lights will hopefully get the correct signal, which looks like it gets forked off (at least to the Driving Support ECU, Stop Light Control Relay, and Skid Control ECU/Brake Booster with Master Cylinder). While driving, there'd probably be some warning lights as it detected the malfunction, but it'd probably still drive safely. And presumably, it wouldn't start again.
    Of course, if you dare to try that mod, be sure to test it out while moving very slowly in a very empty parking lot. :) It's not something I'd try!
