Prius in desert climates?
Discussion in 'Gen 3 Prius Technical Discussion' started by hlunde, Feb 8, 2012.
  1. Former Member 68813
    3,524
    983
    US
    LOL, all you said is completely false.
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Not ALL of it. ;)
    The Lithium Ion battery IS only available in the PiP. :p
    SCH-I535
  3. GregP507
    GregP507 Senior Member
    3,002
    481
    Easy to say; harder to support.
    I did my research beforehand: NiMH vs. Li-ion batteries - A battery Comparison
  4. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Its an interesting topic. I'd be interested if you have any other references as the one you quote has a few problems
    • It focuses on tiny batteries, eg cell phones, not the size we have for traction batteries
    • It says that NiMH has a higher energy density and then says the Li-ion is smaller
    • It doesn't quantify what it means by hot temperatures or hot weather and it does not mention the nature of the problems which could presumably be anything from a slight voltage change which is a problem in some electronic applications to total battery failure.
    • It makes assertions but does not support them by data or reasoning within the article or reference to sources where they can be verified
