Prius in Snow???
Discussion in 'Newbie Forum' started by trinck44, Apr 15, 2009.
  1. trinck44
    trinck44 Junior Member
    Mount Sinai NY
    How does the Prius handle in the snow and ice??
    I live on Long Island and although it doesn't snow often I would like to hear others experiences dring the Prius in snow, ice etc.
    Thanks
    Tom
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It does OK as long as you use the appropriate tires. The original Goodyear Integrity tires that come on the car are not suited for snow/ice.
  3. Prius_SGP
    Prius_SGP New Member
    58
    Saint Genis Pouilly, France
    I agree with firepa63. I live in a mountainous region and we get a fair whack of snow each year, so snow tires are obligatory here.
    I found that the Prius is remarkably easy to drive in the snow. I have a lot more confidence in driving this car then any of the others that I regularly drive for work (pugeot and citroen vans and the 107). It may be just be the fact that I have new snow tires on this car, but I find it remarkably stable and have had no problems even in deep(ish) snow and on hardened ice/snow.
    If you do a search on the forums you'll find lots of posts and comments.
    Personnaly I recommend the Nokian WRG2 snow tires if your wanting to go that way. I haven't had the need to use chains (wouldn't really want to unless totally necessary).
    If you are wanting to drive on the same set of tires all year round then I would suggest that you invest in a good set of all season tires as opposed to the factory fitted Goodyears - they have a rather large amount of bad reviews for certain people.
  4. drash
    drash Senior Member
    2,558
    1,301
    Upstate NY
    Being from upstate NY, the first thing I found out was the Integrity's suck in the snow. I have Michelin X-Ice and my daughter has Blizzaks on her 06. A world of difference but I get a little better gas mileage than she does because mine P-metric radials. The Prius as a whole tracks very well in the snow and/or light icing and have had zero problems with cornering and hills once the snows are mounted.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    I love the way it handles in snow. VSC makes it control very well, although as others have said, you need to get decent tires.
    The Prius is not a truck. It sits low, so you won't be able to wade through deep snow.
    Tom
  6. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    My nephew in Minnesota has driven to work every day in his Prius since 04, and hasn't had any problems in the winter--even with the OE all-season tires. He does recommend the stability control option.
    If you have to drive in snow, I would recommend snow tires. All seasons are only good for cold temperatures and light snow.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I just upload the video back from the early March. We got 10 inches of snow.
    Somehow, the 16:9 video got upload in 4:3 ratio.
