Prius installed map. Is there a way to replace specified map for one more driver friendly like Waze
Discussion in 'Prime Accessories and Modifications' started by Davis T, Apr 22, 2019.
  1. Davis T
    Davis T New Member
    Fort Worth
    I would like to change out the map installed by google to one more driver friendly. Is there one like a waze map that can be installed in lieu of this antiquated map produced by Toyota.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I think both Google and Waze use the same underlying maps. Google has owned Waze for about 5-6 years now.
    52,818
    nope, unless you install aftermarket h/u
  4. kevin.c
    kevin.c Member
    98
    76
    sf bay area
    If you didn’t buy yet, and you are an iPhone user, you could wait for next model year which is rumored to have CarPlay - https://priuschat.com/posts/2879008/
    Otherwise you could consider the new corolla hybrid.
  5. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Or, use the iPhone for audio input and the Waze voice directions will play on the car audio system.
  6. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Or do what I did and get a phone mount and just run Waze on your phone. Also, you can play phone audio through the car via bluetooth (no wires needed!) However, I did buy a USB cigarette lighter so I could keep my phone charged during long trips.
  7. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Do you find that the provided USB port does not provide adequate power?
    George Suematsu likes this.
  8. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Pretty much. It couldn't even stop the battery on my phone from draining even under normal use (i.e. waze + phone music). Does seem like Toyota really underpowered those ports.
  9. WhiteRabbit
    WhiteRabbit New Member
    Northeast
    2018 Prius Prime
    I have a USB-C adapter in the 12v cig lighter and run a lightning to USB-C for the phone -- fast charging and I can top off my laptop or iPad Pro if I want...
  10. bisco
    52,818
    :sleep:
    kevin.c likes this.
