Prius is leaking coolant
Discussion in 'Gen 2 Prius Main Forum' started by Deacon Jones, Nov 27, 2023.
  1. Deacon Jones
    Deacon Jones Junior Member
    Moore norman
    Hello so today my car decided to surprise me And is now just pissing out my coolant from my tank close to the top the one connected to the electric box thing idk I’m frustrated
    Anyways it looks like it’s coming from my radiator fan but I can’t seem to find out what it is coming from can anyone help me? It would be greatly appreciated
    52,776
    perhaps the water pump?
  3. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    So it looks like it's coming from in front of the fan just below the thing that says hybrid synergy drive and has a silver lid on it the inverter more than likely you're going to have to undo the 10 mm bolts on your fan or fans and lean them back You can push them back a little bit so you can get a view in there if it's pissing water that means it's under pressure so it's got to be coming from the radiator so more than likely the radiator is going to have to come out The plastic tank that holds coolant is not under pressure so it wouldn't usually piss out of there it could be cracked and leak but it wouldn't squirt like it was under pressure pissing or streams is generally under pressure it'll be coming from the aluminum radiator assembly.
  4. PriusCamper
    PriusCamper Senior Member
    13,403
    5,412
    Pacific Northwest, USA
    That's near the location of the radiator cap... I bet once the engine is cold again you can simply replace the radiator cap and top it off with coolant and it'll be problem solved.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    PriusCamper likes this.
  6. Deacon Jones
    Moore norman
    Right we that one is holding stuff it’s the other one next to the hybrid thing
  7. Deacon Jones
    Moore norman
    It’s the one next to the hybrid silver thing that’s just pushing it all out
  8. Deacon Jones
    Moore norman
    It’s more like it’s just rapidly draining also if I did have to replace the radiator how much would that cost do you think?
  9. Deacon Jones
    Moore norman
    I don’t really have any it was hard to just see what was happening I can try to take some when I get to trying again
  10. Tombukt2
    13,809
    2,504
    Durham NC
    If you go out and look at a car at a junkyard or see your radiator at a shop for this car you'll see it's two radiators if you will anyway regardless of all that I have three laying here and I got them all for nothing and anytime I'm over at LKQ I can grab another one I just usually don't because these things almost never get replaced or it is very rare other than a front accident.
  11. qmanqman
    qmanqman Active Member
    443
    153
    CO
    All you're gonna get here are guesses. You, and only you can find the leak.
