Prius issues
Discussion in 'Gen 2 Prius Technical Discussion' started by BrimerShannon, Jan 9, 2022.
  1. BrimerShannon
    BrimerShannon New Member
    Kansas, United States
    bought my first prius its a 05 hybrid hatchback had frontend damage from a deer i replaced all the broken parts finally getting somewhere or so i thought before a fixed the broken parts i was getting nothing be blinking amber light now i get a green light with once push on the second push a get one flashing of amber light then it gos away and check engine light flashes and gos away the no light on power button brand new battery i also charged it over night thinking that was it but nope same think i'm at a crossroads and dont know which way to go to find my problem also all fuses and relays was check and are go
    52,404
    techinfo.toyota.com
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,097
    1,999
    NJ-USA
    Welcome to Priuschat! First- please consider using periods, commas, and paragraphs when you post. Run on sentences make it difficult for others to read and interpret your posts.
    Now, do you have a digital multimeter, and if so can you measure what the voltage is at the "jump start" point under the hood when you try to to ready the car up? Do you know that the key fob you have is correct for the car- does the remote lock-unlock buttons work?
    Also, do you have any scan tool that is capable of reading codes on a Prius? Many here get a miniVCI cable with a bootleg copy of Toyota's Techstream diagnostic software and install it on an old windows laptop.
    Another and Mendel Leisk like this.
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat!!
    Sections titled P2MY06 are the latest : La documentazione del selidori
    FYI : you're moderated until you've posted 5 times.
