Prius keyless remote malfuntion causing alarm to go off every few minutes
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Rajesh Nerurkar, Apr 30, 2014.
  1. Rajesh Nerurkar
    Rajesh Nerurkar New Member
    Charlotte, North Carolina
    Recently my keyless remote was wiped with wet paper towel to get rid of some detergent the fell on it. Since then the alarm has been tripping for no good reason. The only way the alarm stops is when i open the car with my key and put the remote in the keyless remote holder. Can anyone advice what the issue is and how to fix it?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Sounds like some water got into the remote and is causing problems. You can try taking the remote apart (like changing the battery) and use a hair dryer on low heat setting to dry out the circuit board and buttons. Then reassemble everything carefully, making sure none of the buttons are being pressed down by a misaligned case.
    SCH-I535
  3. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Deliberate work the alarm a few times, that may fix it.
    49,500
    welcome to priuschat! do you have a second remote?
  5. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I agree. Take the remote apart and clean out the detergent and water. Reassemble. Just like you would do to a tv remote that got something spilled on it.
