Prius LE auto headlight retrofit
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Adam Adamovich, Aug 6, 2024.
  1. Adam Adamovich
    Adam Adamovich Junior Member
    United States
    2023 Prius
    Hey there, does anyone know how to retrofit auto headlights instead of manually turning on lights without swapping front light units. I saw that even the base Canadian SE models get auto lights as standart with base headlight units.
  2. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    You don't need to do a retrofit; I have an LE, and although there's no auto setting on the lights, I was able to change the settings in the Multimedia to be able to turn on the headlight switch and leave it on. What will happen is when you park, the lights remain on until you open the doors, then they will turn off automatically. This way, there's no need ever to touch the headlight switch going forward.
    Caleb2007 and soft_r like this.
  3. ChapmanF
    18,970
    Gen 5 I don't know, but some trims of gen 3 came with an actual "auto headlight" feature that would turn them on at dusk and off in light. It relied on the solar sensor that was already on the dash in all trims (used by the HVAC to adjust for comfort driving into sun or shade).
    It turned out the car's body ECU already knew how to do the auto headlights, and trims without the feature simply didn't run the extra wires (from the sensor to the ECU, and from the 'auto' headlight stalk position to the ECU).
    In a trim that didn't come with the feature, adding those wires was all it took to add the feature.
    What I found to be the best thing about the feature is it takes over control of the dash brightness. Instead of the dash always being dim whenever the headlights are on, it's dim when the headlights are on in the dark, but brighter when headlights are on around dawn, dusk, or daytime. That part by itself was worth the price of admission.
    Adam Adamovich likes this.
  4. Adam Adamovich
    United States
    2023 Prius
    Cool, I do have the light sensor housing on the dash, but not sure if it actually has a wire inside it. Have to plug it out and see. I dont know why toyota make this feature standard as its cheap to do so
  5. Adam Adamovich
    United States
    2023 Prius
    Yeah, but then your dash will be night mode brightness. I cant really see at that level. Also your back lights will be on during the day too. On top of that i feel like you're going to wear out the main light unit, rather using the led strip like on top models
