PRIUS MAGNETIC OIL DRAIN PLUGS
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FloridaWen, May 21, 2007.
  1. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Drain plug magnets are a good idea but about the only engine item they really protect (providing the oil filter is doing it's job) is the oil pump as this is between the oil sump and filter, it therefore pumps unfiltered oil and this can usually be seen in a dismantled pump as scoring witch reduces oil pressure and flow rates.
  2. WX4GPS
    WX4GPS Junior Member
    64
    TMMK Georgetown KY
    What size drain plug on the Prius C? I would like to get one for the C
  3. Mike500
    Mike500 Senior Member
    2,593
    767
    The same M12x1.25 as in all late Toyotas.
    I have a Sherline micro lathe. I just buy some neodymiun rare earth rod magnets that are 1/8x1/2, drill 1.8 inch hole 5/16 inch deep into the center of the OEM, and fit them in with green engine sleeve retaning Loctite.
    It goes in as the OEM drain plug.
    For those, who doubt the effectiveness of a magnetic drain plug in a aluminum engine, all 4 cylinder Prius engines use an iron cylinder liner.
  4. talonts
    talonts VFAQman
    468
    76
    Unfortunately, the price is now $14.99. Just a little increase :-/
