Prius making popping noise.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Misst, Jan 4, 2022.
  1. Misst
    Misst New Member
    CA
    I was hoping to get some information on why my 2011 Prius is making a popping noise when I'm backing up. It seems to happen when I've just turned the car on and started moving. It happens easily within 2 or 3 seconds in. This has happened three times over the past month. Never happened before.
    I'm hoping to get some info on this before I take it in to get checked out so I have an idea.
    49,432
    how many miles on her? can you get a recording?
  3. ChapmanF
    15,561
    You're not, by any chance, reversing through a swamp where popping noises usually precede a flame spurt?
  4. Misst
    Misst New Member
    CA
    Nah. Every time's been in a simple, concrete parking lot in LA. I've checked and found no plastic bottles or anything that has caused this sound before.
    I'll have to get back to you on the miles and this happens so uncommonly that getting a recording would be a fluke.
    #4 Misst, Jan 5, 2022
  5. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Sometimes the brake rotor's surface can get a surface layer of rust formation that makes the brake pads "stick".
    The brake disc will break free of the brake pads when the car moves, which may sound like a popping sound.
    I find it happens most often when parked after the rotors are wet, like after driving on wet roads, or if you park outside and dew accumulates on the disc and forms that layer of rust.
  6. bisco
    49,432
    i think you nailed it ^
