Prius making sounds every few seconds since oil change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Comf, Jun 13, 2023.
  1. Comf
    Comf New Member
    Tennessee
    Ever since I got an oil change this evening my Prius started making this noise like something is trying to engage followed by a whirring noise for 20 seconds, then it stops for 15 seconds and does it again every time. The oil was Full Synthetic 5W30. I would post a video but it's not letting me.
  2. Comf
    Comf New Member
    Tennessee
    It sounds like it's coming from here in this pic. I can hear the engaging noise from the cabin but can only hear the whirring noise when I pop the hood.
  3. ChapmanF
    19,047
    Sound a little like a joy buzzer or a rattlesnake?
    You can search around this site for threads about the brake system pump, and probably find several with recordings or youtube links you can listen to and compare the sound.
  4. Comf
    Comf New Member
    Tennessee
    Neither. I know what the brake actuator failing sounds like because I've had to replace mine and it's different.
  5. Comf
    Comf New Member
    Tennessee
    I'm gonna make a few posts In the hopes I reach
  6. Comf
    Comf New Member
    Tennessee
    what I think is the minimum post count (5) to post a video of the sounds
  7. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    How old is the 12v, and what voltage are you getting at the jump points under the hood?
    FYI : you're moderated until you've posted 5 times.
