Prius manhole
Discussion in 'Gen 3 Prius Technical Discussion' started by saltdiscus, Oct 31, 2021.
  1. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
  2. xliderider
    8,140
    3,280
    Honolulu, HI
    It's basically a length of flat steel bar, a metal fabrication shop could easily make that piece for you, and even make it out of heavier gauge material if you like.
    #22 xliderider, Nov 1, 2021
  3. ChapmanF
    18,998
    When I click on the part number link given in post #15 above, the first ten search results I get are all Toyota dealer, amazon, or amayama links. It doesn't seem difficult to find.
  4. saltdiscus
    saltdiscus Member
    198
    89
    US
    Hi
    Yes it’s just a straight metal bar with 4 holes on each side but why can’t I find the part number in Toyota directory. This bar came with 2014 Prius lvl two and looks like Toyota doesn’t sell replacement rod.
  5. saltdiscus
    saltdiscus Member
    198
    89
    US
    That’s not the part which broke its a different rod.
  6. saltdiscus
    saltdiscus Member
    198
    89
    US
    link from post 15 part number
    53605-12021 doesn’t fit with 2014 Prius.
    As of right now there is no aftermarket reinforcement bar for 2014 Prius. I do see for gen 1 ,2 and 2010-2013. I have been looking 2014 and 2015 reinforcements bar oem part number and there isn’t anything here. I also called Toyota parts and they have no idea without the part number.
  7. Mendel Leisk
    42,314
  8. drbtz
    drbtz Member
    102
    51
    United States
    Always defer to someone who knows more (y) Thanks for the enlightenment and new info!
  9. ChapmanF
    18,998
    The link I put in #15 was
    maybe you copied the 4 as a 1?
    Says here it superseded the -47020.
  10. Mendel Leisk
    42,314
    Amayama can have superseded parts, at least that was the case with my oil filter conversion, where there was several versions. There must be a reason for revision, but older part is hopefully serviceable.
  11. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Any updates on how is your Prius doing today?
