Prius Marathon Run
Discussion in 'Gen 2 Prius Main Forum' started by efusco, Jul 31, 2005.
  1. lbligh
    lbligh Member
    137
    24
    Northern Virginia
    My whole family was eagerly following this event all weekend. I would bet that an awful lot of PriusChatters were doing the same. Gentlemen, we really do want to know all about your experience, and no detail is too small.
    For example, my husband wondered if you used the stereo system or not? What was your average speed? Did you often drive very slowly? Did you keep the windows up all the time? Did you take off your radio antenna?
    This has been more fun than the Tour de France!
  2. rflagg
    rflagg Member
    947
    Springfield, VA
    Congrats guys! It was great to meet you all - Dan, Bob, Dave, Rick, Wayne - you are all my hero. I had to head out of town at 1280 miles, right after a little talk with the HBO crew and when Dan took over the final segment. Tonight I'll post some pics of the record-breaking car and owner when I get home from work. Again I had a great time meeting you guys and not only being there for the record breaking tank, but also being able to check out the 2nd highest-in-the-world insight LMPG and the HCH that averages in the 80s. I think just having my car near yours gave it incentive to average a solid 53MPG when driving 70-75 on the 255mi trip home. :)
    All that aside, when's the next attempt at smashing this record? 12.78 gallons, that means you could go to 1500 easy! :) :p
    -m.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    They averaged about 2 minutes per shift change, so probably a grand total of 30 minutes of 'stop time', not counting traffic lights and stop signs (which they kept a tally of but haven't posted a final tally of yet).
  4. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Evan,
    The shift changes took closer to 5 minutes each and there was a stop at each end.
    Total Stop Signs 96
    Total Traffic Light Stops: 300
    Total Traffic Light Slowdowns (below 20 MPH): 174
    Assume 1 minute for each stop light, 1/2 min for each stop sign and 11 shift changes, that comes to 403 mins or 6 hours. Subtract that from 47.75 hous and divide by 1397 miles.
    That calculates to 34.1 MPH. Our target was 30-40 so that sounds about right.
    Dan
    Average speed
  5. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    The Prius Marathon Run was great entertainment for me over the weekend. I applaud all of those participating. I hope the media picks it up to counter the articles saying the EPA figures can't be achieved.
    I would sure like someone to describe in detail the driving technique used. I assume acceleration to about 40 mph was attempted so that no arrows showed to or from the battery, but how can this be achieved? Seldom can I do this from a standing start, as almost always current flows from the battery upon acceleration. I can accelerate until the ICE goes faster, then let off on the accelerator looking for the lack of arrows, or I can try for no arrows early on in acceleration, making for slow going. And how were you accelerating from 30 mph? Or, did you use quick acceleration, either from standing to 40 or 30 to 40, and if this was used, how quick? And after acceleration, when I try to go into glide, it seems that I must take my foot fully off the accelerator, wait until the green regeneration arrows show, and only then can I put light pressure on the accelerator to glide. Is there a way to minimize the slowing caused by regeneration? Or better yet, go into glide with no regeneration?
    CraigCSJ 04 Driftwood #9BC
  6. ltu1542hvy
    ltu1542hvy New Member
    338
    Cotonou, Benin
    In the Wishful Thinking department, it would be nice if someone could come up with a "glide mode switch mod" similar to the EV switch mod, where pulling a lever or pushing a button would put the car in glide mode without regen if the foot is left off of the accelerator.
    Then again, not having this does give me a convenient excuse to ask my girlfriend for ankle/foot massages :mrgreen:
  7. v.jones
    v.jones New Member
    101
    New Jersey north of NYC
    You don't need a "glide mode switch mod" because you already have that function built in and enabled...To activate: Grab the gear shift knob. Push it straight to the left and hold until the "N" (as in "neutral") is circled on the dash indicator. You are now locked into glide mode. To exit glide mode, use the gear shift knob to select any other appropriate gear (presumeably drive or brake, but I suppose the next challenge will be the ultimate gas tank running in reverse :)
    Disclaimer: you need to check your local DMV rules, as coasting in neutral is against the law in many states/jurisdictions.
    Vince
  8. LOLGuy
    LOLGuy Member
    177
    22
    Tampa, FL
    Congratulations, guys!!!!!
    ...and I thought 55.5MPG on my most recent tank was good.
    Again, wonderful job to all!!!
  9. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    DMV rules are moot in this instance as there is absolutely no way to enforce this law.
  10. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    What do these anti neutral laws actually say anyways? To me a neutral gear means you are disengageing some gear. I don't see how the law applies to a Prius.
    In a Prius the N position would be closest to a regular car if it could switch open the engine valves on command and cut off the fuel supply.
    And as far as these laws are concerned seems to me they worry about a conventional car taking too long to shift back or something? In a Prius I can get back to drive far quicker than I can downshift in a normal manual transmission car, so there is less danger of delaying any acceleration that might be needed.
  11. jtmhog
    jtmhog Member
    151
    In the Prius, N doesn't disengage any gear. It opens an electrical switch which disconnects MG2 from rest of the electrical system and thus, no regen. The ring gear just spins with no movement/power to the planet. For more info, go to Graham's site.
  12. ltu1542hvy
    338
    Cotonou, Benin
    Time for a self-LART. Sorry for wasting bandwidth by blabbing away at the keyboard without engaging brain first (although it was due to a lack of caffeine, but still...). Yes, shifting it to "N" would do it. Thanks for pointing that out...
  13. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    I am a municipal police officer (25 yrs). I occasionally see reference to driving in neutral (is that an oxymoron) being illegal but I have never seen a link to such a law nor have I seen a particular code referenced. Ohio, as a state, has no such law. I suppose a municipality may have one. I suspect this "law" resides in the same codebook that prohibits driving while bare-foot.
    So, all those who say there is a law against it, tell me where. (State and city in US please)
  14. efusco
    19,891
    1,194
    Nixa, MO
    I actually think the "glide button" would be very nice, and it would not be anything like going into neutral.
    It would be a combination of:
    1)EV button-like to turn off the ICE
    2)disingage regen
    3)Automaticaly be disengaged when either a)accelerator pressed, or b)brake depressed and then would resume normal function without the need to press the button a second time.
    That way you could accelerate out of a problem situation if need or have regenerative braking without doing anything special (like hitting the knob again). Also, if the batter SOC got low ICE could kick in to recharge where that would not be possible in Neutral.
    I've done the Neutral thing and it's a PITA to remember to put it back in drive as you approach a stop while watching for traffic and keeping your eyes on the road, etc. A simple button on the wheel that allowed glide when hit with the foot off the accelerator then had the features I describe would be very useful to me.
  15. Godiva
    Godiva AmeriKan Citizen
    10,339
    When I visited my cousin in Connecticut she took her shoe off and drove barefoot. She told me it was illegal and if she was pulled over would just slip it back on. Not sure what county. We were driving from Bozrah to Mystic.
    Of course....how would you enforce such a law? It's not like you can see people's feet while they're driving. And unless they don't bring their shoes with them, they can do like my cousin and just slip them back on before an officer gets to the window to look in.
  16. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Astounding job, guys -- congrats and thanks for putting forth the
    effort. May your right ankles never falter. And I
    thought touching 77mpg for a while on some test runs
    up here was pretty good...
    About barefoot driving et al: check out
    www.barefooters.org, and print yourself some of the material
    they have available if you're paranoid about getting
    hassled.
    And as several have already noted, neutral is a
    complete red herring where the Prius is concerned.
    _H*
  17. Starman
    Starman New Member
    Springfield, Missouri
    Many states and municipalities in the US have enacted laws banning the operation of a motor vehicle in "neutral." The Uniform Vehicle Code, which has been adopted by many jurisdictions, states, "The driver of any motor vehicle when traveling upon a down grade shall not coast with the gears or transmission of such vehicle in neutral." Here are a few other illustrative examples of "coasting" laws. Many more could be cited.
    Oregon Statutes 811.495: "A person commits the offense of unlawful coasting on a downgrade if the person is the driver of a vehicle on a downgrade and the person coasts with the gears or transmission of the motor vehicle in neutral or with the clutch disengaged. This section does not apply to the driver of a motorized bicycle. The offense described in this section, unlawful coasting on a downgrade, is a Class C traffic infraction."
    Louisiana Statutes 32:285: "The driver of any motor vehicle when traveling upon a downgrade shall not coast with the gears of such vehicle in neutral or with the clutch disengaged."
    Seattle Municipal Code section 11.58.010: "The driver of any motor vehicle when traveling upon a downgrade shall not coast with the gears of such vehicle in neutral. No driver shall coast with the clutch disengaged when traveling upon a downgrade. This section shall not prevent the proper shifting of gears or the towing of a disabled vehicle."
    Many other states and cities have similar laws. The good news is that coasting uphill is not prohibited!
  18. AnOldHouse
    AnOldHouse Member
    677
    Middlesex County, Connecticut
    New London County, although in Connecticut, counties don't really mean anything as they do in other states.
    I like driving barefoot (or sock-footed) as well. For me, I get a better "feel" and contact with the pedals. Considering some of the extremely impractical footwear many people wear, I think it would be far safer to drive barefoot. Must be a Connecticut thing?
  19. tomdeimos
    995
    Lexington, MA
    The way those laws are stated I don't see how it applies to a Prius.
    Our gears don't disengage and we have no clutch at all.
    Now if you argue it is Neutral because the lever is labeled "N" that is weak too since electrically and mechanically in the transmission the "N" switch doesn't do anything different from holding the accelerator in the coast mode.
    They are identical except one lets your foot rest.
    Now if coasting down hill is illegal that means it is just as illegal to do using the accelerator in the coast position too!
    But when they talk about coasting down hill, that is what several Saab's I've driven did by design with their built in free wheel and the car was fully legal, but that was back when a lot more people wanted to conserve fuel! When you went down hill the gears were automatically always disengaged unless you stopped the car to lock the free wheel. You weren't supposed to do that while moving. And I drove that car all over Oregon too!
  20. DieselConvert
    DieselConvert Member
    121
    Central Coast, CA
    I'll check with Graham's site again (great stuff!) but feel certain that I saw the green arrows on the MFD from wheels to battery when I selected N on a long downgrade recently. I felt a slight acceleration soon after pushing left on the selector, and N was highlighted on the odometer display. Yes, the acceleration does indicate that the "drag" of the regen had been disconnected. Maybe the energy display has a glitch? :?
