Prius Mechanics in Boston Area
Discussion in 'Gen 2 Prius Main Forum' started by Bluesman78, Mar 5, 2017.
  1. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    I've tried my best to look online for a non-dealer mechanic who can work on Prius. I mean more simple things like draining the transmission fluid without explaining it needs the toyota replacement, etc.
    I'm looking for the Boston/Somerville/Cambridge area. Given the demographics of this area either every mechanic does this or there have to be some that only work on hybrids.
    Thanks again!
    C Wagner likes this.
  2. Mendel Leisk
    42,364
    For stuff like transmission fluid changes maybe a PriusChat member in the area can help you out? It is a pretty easy DIY. From reports here, most of the cases of wrong fluid being used are non-dealer mechanics, fwiw.
    The name of the game is raise/level the car, drain, fill with Toyota ATF WS, till it starts coming back out.
  3. Prodigyplace
    12,720
    11,852
    Central Virginia
    Perhaps when he returns from vacation, @bisco could be of assistance.
  4. JC91006
    16,937
    8,647
    Bisco? He doesn't even change his own oil
  5. Currahee
    Currahee Member
    103
    34
    CT
    There's a DIY auto shop about an hour away in Providence, with mechanics on hand to help. Haven't been there myself but it seems popular.
    SFO likes this.
  6. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    SFO and bisco like this.
  7. Mendel Leisk
    42,364
    To have a decent chance of getting it done right, with the transaxle fluid change: bring your own bottles, the right stuff. And might as well bring the fill and drain bolt washers. Then, they'll probably use a pump that's been used to pump other fluids, so there'll be some contamination, depending on how well they cleaned the pump.
  8. bisco
    52,878
    as you said, any mech in cambridge/somerville should have the knowledge and experience. just quiz her before giving the go ahead.
  9. Prodigyplace
    12,720
    11,852
    Central Virginia
    All the mechs in canbridge/somerville are female?
    You learn something new every day here :D
    Thanks, Bisco.
  10. bisco
    52,878
    oh ya, luscious. i mean, brilliant.
    Prodigyplace likes this.
  11. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Well, the Brilliant ones are. I understand all the Luscious ones are all in SF. (y)
  12. bisco
    52,878
    look for a triple a rated mechanic, i think they have to meet some standards.
  13. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    An A for AA, perhaps? :rolleyes:
  14. C Wagner
    C Wagner Member
    183
    60
    Boston
    What stupid answers you all gave to a decent question: “where are the specialist (Prius only...)” mechanics in the Boston area...
  15. bisco
    52,878
    uh-oh :oops:
  16. StirFly
    StirFly New Member
    Boston area
    2014 Prius c
    Leaving aside the nonsense above, does anyone know of a good non-dealer Prius-capable mechanic in the Arlington MA area, specifically one with experience diagnosing issues with the hybrid system?
  17. StirFly
    StirFly New Member
    Boston area
    2014 Prius c
    Any experience with Firestone?
    They say specifically that they service hybrids, have a shop fairly semi-close.
  18. bisco
    52,878
    Stay away from chain shops, they lie more than dealers.
    For funsies, ask them if they have Toyota tech stream diagnostic software, and if yes, describe your issue to them and report their response here
