Prius Minivan Coming in 2011 with Lithium-ion batteries?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Danny, Apr 16, 2010.
  1. Navigare
    Navigare Active Member
    312
    138
    Netherlands
    I drove next to a Toyota Sienna today, probably imported from the States because they don't sell it here in het Netherlands.
    I thought it was húge.;)
  2. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Voltage increases from 201.6 to 345.6 for the battery-pack. We know that already from the plug-in model of Prius.
    What hasn't been revealed yet is the voltage the system itself operates at. 650 volts was the maximum, due to patent/lawsuit restrictions for NiMH. Switching to Li-Ion elimates that artifical limitimation.
    Higher voltage can equate to improved power or efficiency.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I thought NiMH patent was limited for the capacity. Anything more than 8 AH was considered large format. I did not know about the voltage limit as well.
  4. austingreen
    austingreen Senior Member
    13,668
    4,209
    Austin, TX, USA
    motortrend reported that the Li battery would weigh 1/3 what the Nimh battery in the prius.This would also shrink the volume the battery takes up. Its likely from that figure that capacity is lower, but usable capacity would be similar and maximum power higher. So lighter with greater maximum regen braking.
    I'm sure toyota has worked with the charging and battery chemistry to keep the batteries away from the run away conditions in the sony batteries in dell and other laptops.
  5. john1701a
    12,817
    5,303
    58
    Could have been. Somehow voltage limitation played into the equation though. History that I have forgotten apparently. Hopefully there's that bit of detail noted somewhere.
    Whatever the case, I do like the modular design of the plug-in model. It contributes nicely with new non-plug hybrids like this.
  6. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    WOW, I could go for a hybrid version of this minivan, provided it gets similar (or better) gas mileage to Navigare's diesel Verso (by my calculation, 39.37 mpg). I'd jump on that deal in a minute. One Prius and one hybrid Verso would be a perfect combination for our needs.
  7. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Don't you mean to narrow for American butts?
  8. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    Of course its the cars that are too narrow, as there is certainly no issue with North American butts.
    You simply need a corresponding obese car, like a cross-over / SUV (am I the only one thinking the Venza is a an obese hatchback Camry?).
  9. Tideland Prius
    16,536
    Hey, I was being nice here... after all, I am Canadian ;)
  10. Navigare
    312
    138
    Netherlands
  11. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Yeah I just saw theses pics over at GMI. Hellooo..
    This is a lot sharper than the initial pics shown above. It also seems to be on the roads hereabouts by the architecture and other vehicles [duh..read the article]. Does that mean a Spring launch to be announced at NAIAS? That'd be nice.
    Mini-minivan / RAV / CR-V sized MPV with a hybrid powertrain it appears to be.
  12. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    any offical size of this van
  13. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    40 MPG 7 seater Prius would be a winner.
  14. Tideland Prius
    16,536
    Judging by the pics, it looks Mazda5-ish in size... not a bad guesstimate given the Mazda5 to the Mazda3 size difference isn't great; I expect similar ratios btwn the Prius Alpha and the Prius.
  15. Airbalancer
    892
    73
    Cobourg, On, Canada
    I could use a little more room
  16. Navigare
    312
    138
    Netherlands
  17. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Booo..
    Just 2 years into a 5 year note on our Nissan Quest.. we love it...
    Now about my PHV Prius....
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Ok, that sticker on the dash confirms it'll run on regular gas.
    The bridge dash is gone too. It is more like Gen2 Prius with shifter near the steering wheel. The speedometer display is closer to the dash and it looks like it can close too.
  19. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Looks more like a 5+2 seating, the third row is good for two small children.
  20. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Following is not official, but,,,
    4590mm(L)×1770mm(W)×1585mm(H)
    source
    Unfortunately, JP rumor said as follows;
    Prius Alpha: 7 seater with Li-ion battery located between front seats for JP market only
    Prius V: 5 seater with NiMH battery located at rear luggage space for global market
    Ken@Japan
