Prius moonroof (Panoramic) wont close anymore
Discussion in 'Prius v Technical Discussion' started by Profanas, Apr 27, 2020.
  1. Profanas
    Profanas Junior Member
    35
    Lithuania
    2013 Prius+ MPV
    i have problem with moonroof, he won't close anymore.. maybe somebody have info how fix it? have some sensor?
    All electric engines is in middle roof?
  2. ChapmanF
    19,016
    At first I was thinking there might be some obstruction in the track. That looks like the designed behavior where the window encounters an obstruction and reverses.
    But then seeing the rear one do the same thing ... ? Hmm. An obstruction in both tracks?
    It's certainly worth checking for anything obvious that's mechanically in the way.
    If that doesn't yield a solution, I think I would go straight to the Repair Manual (more info) for ideas. The mechanism is up over the headlining, and the headlining is tedious to take out (and also not super robust), so I would want to run through the details a couple times on paper (or monitor) before tearing into it in real life.
    Edit: wait wait wait wait. Maybe simpler. Has the battery power been interrupted recently?
    There might be an initialization to perform so the mechanism learns its correct closed points. It might even be covered in the Owner's Manual so you wouldn't need the Repair Manual. It possibly would involve holding the switch down in the 'close' direction for several seconds.
  3. Profanas
    35
    Lithuania
    2013 Prius+ MPV
    I cleaned track and i sprayed with wd40 oil.. track are clean.. :/
    I found how calibrate moonroof, i Did that, but still.. same problem.
    Now i disconnected battery for 10min.. maybe have some Error.
    #3 Profanas, Apr 27, 2020
  4. Profanas
    35
    Lithuania
    2013 Prius+ MPV
    maybe somebody have electric scheme for this moonroof? maybe problem with some relay or some electric part.. bus still i cant find engine, i need take roof off? :(
    #4 Profanas, Apr 27, 2020
  5. ChapmanF
    19,016
    See the link in my earlier post. Repair manual and wiring diagram there. The web address for EU should work for Lithuania?
  6. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    WD40 is a Solvent not a Lubricant.
  7. Michael M
    Michael M New Member
    I have found that you can close it almost all the way and then click the closed button again to stop it. This has worked for me (I have had it stop midway a few times throughout the years I have owned my 2012 Prius V).
  8. Gary Rieger
    Gary Rieger Junior Member
    port townsend wa
    at halfway point mine reverses when i try and close it. now i have to pull the wind deflector down and toggle the close button 4 or 5 times at the halfway point to get it closed
