Prius Newbie... Have a question.
Discussion in 'Prius v Main Forum' started by rvijay, Sep 25, 2012.
  1. rvijay
    rvijay New Member
    I am a proud owner of a new Prius V5. I've been driving it for a week now and I am quite impressed. I felt like this car was specifically built for my work commute (stop and go traffic with about a 100 lights in between ...).
    I have a question though. Whenever, I start the car and switch gears (P -> R for backing out of the driveway and then R->D later), I see the yellow "car skidding" icon coming up on the dashboard. For example, it shows up when I apply the brake and stop the car prior to switching from R->D. It goes away once I slightly press the gas pedal and the car starts moving. Is this something that is normal for Prius, or should I talk to my car dealer right away? Also, it never shows up later during my trip (even when I am stopped). Appreciate any insight/help.
    Thanks,
    Vijay.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    It sounds like you are pressing the brakes too hard and enabling the Hill Start Assist feature. Try being a little lighter on the brakes.
  3. rockfeller
    rockfeller Junior Member
    88
    CA
    Welcome and congratulations on your new Prius.
    Before changing the gear from P->R, is parking break released ?.
  4. rvijay
    rvijay New Member
    jdcollins: Thanks for the suggestion. I'll try being easier on the brakes next time and see if it resolves the problem.
    rockfeller: I follow the approach suggested in the manual. The parking brake is released only after I change the gear from P->R (just prior to releasing the regular brake).
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,980
    4,724
    Texas Hill Country
    You are engaging Hill Assist. Read about it so you know how to use it on a hill in traffic so it doesn't roll backward.
  6. rvijay
    rvijay New Member
    Thanks folks ... It apparently was the Hill Assist feature. Learnt a new thing about my Prius today ...
