Prius noob here - mpg questions
Discussion in 'Gen 3 Prius Fuel Economy' started by Remstarasianboy, Jan 16, 2012.
  1. Remstarasianboy
    Remstarasianboy Junior Member
    Austin TX
    2013 Prius v wagon
    I bought a certified pre-owned 2010 Prius IV and have a couple of questions.
    The capacity on the tank is 11.9 gallons.
    I reset the meter and drive an according to the computer I am averaging 51.2 mpg. After driving 467 miles distance to empty says 0. The gas level is at one bar and now beeping.
    I get home and now have 500.2 miles and the light is still beeping. Do I need to fill it up because the tank is empty or can I make it to 600 miles on this tank assuming I am averaging 51.2 mpg?
  2. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
    You need to get gas first thing. You do not know your car yet. Your display reads 51.2 but the actual is closer to 48 mpg.
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  4. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    (deleted, double post)
  5. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    (triple post :()
  6. Remstarasianboy
    Austin TX
    2013 Prius v wagon
    I filled it up myself. This was the 3rd fill up for me. The first time I filled it up at 450 miles when the meter read 22 miles for distance to empty. It just didn't sound or look right. That's why this time I am trying to figure it out exactly. Even if assuming that the actual is 48 mpg couldn't I assume that I can go at 550 miles on a full tank?
  7. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Get fuel as soon as you can I pushed mine out to 600 miles for the first time last tank and put in 11.4 gallons of fuel that is to close for comfort. I would hate to be one of those I ran my Prius out of fuel people. I usually fill up between 500-550 miles, do not think I will push it out to 600 miles again. Like the others have sad there are a few variables, differences with each car and the Constant MPG display numbers are optimistic. What kind of MPG do you get when you do the math?
  8. Remstarasianboy
    Austin TX
    2013 Prius v wagon
    It shouldn't really matter what mpg reading is. When the fuel gauge is at one bar and it is beeping does that signify that there is a particular amount of gas left in the tank? And if so does anyone know the amount that is suppose to be in left when the gauge is at one bar and beeping?
    The actual mpg and computer readout on my display makes no difference because I can figure it out. I just want to know how far it is I can actually drive once the lights start to blink. That way I am not stuck on the freeway or have to exit at the bad side of downtown Los Angeles or one of the side cities I am nor familiar with.
  9. walter Lee
    1,126
    376
    Maryland
    When the Prius gas fuel gauge is on the last bar and that last bar starts blinking (there is also an initial beeping when it start blinking), the Prius has slightly more than 2 gallons of gasoline left. The Prius onboard computer is normally about 3 mpg overly optmistic (sometimes it can be off by as much as 5 mpg) so if the MFD says you have sofar average 51 mpg it suggest that you are probably getting about 48 mpg when calculated at the pump. This suggests you have an rough estimated 96 miles (2 gallons at 48 mpg) before you run out of gas assuming uniform driving conditions ( The Prius MPG can drop like a rock in traffic jam lasting over 15 minutes - if you use the cabin climate controls, e.g. Heater, defroster, Air conditioner, while sitting in traffic.). Therefore, if the last gas fuel gauge bar started blinking 467 miles on your trip odeometer that suggest (if your driving conditions donot change) that the Prius will likely run out of gas about the the time when the trip odeometer reading is getting close to 565 mile. Given your current performances of 48 mpg for atleast the last +9 gallons, you'll need to improve your fuel efficiency on the last two gallons of gas to 70 mpg to achieve 600 miles on this current tank. From testimonies that I've read sofar, people drive very fast on the LA freeway and getting +55 mpg is unlikely. While one can drive the Prius past the 0 miles to go point, it is not advisable to allow the fuel tank to go completely empty because it puts added mechanical stress on the fuel pump and could shorten its lifespan.
    hope this helps
    Walter Lee
    (aka "HyperDrive 1" on Cleanmpg.com)
    2010 Toyota Prius III, Blue Ribbon/Dark Grey, oem floormats
    Yokohama Avid S33D(50psi/48psi)
    ScangaugeII (Fwt/AVG, RPM, SoC, GPH)
    grill blocking (100% top,100% bottom)
    Odeometer +18800 miles, overall 60.9 mpg
    best tank 70 mpg
    worst tank 52 mpg
    last tank 58 mpg
  10. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Actually the TRUE gas tank capacity is over 11.9 gallons. Probably close to 13.5 gallons. When you fill your gas tank when the pumps first clicks off you can still put in about 2.0 gallons of gas which would fill it up to the brim / filler neck of the tank.
    I know this practice if not normally done during routine fill up but
    that would be your TRUE gas tank capacity.
    alfon
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Why do people always try and second guess the car? If it says get gas then go get gas. I don't understand why people play these games. It's not like you live in Australia and have to drive hundreds of miles between gas stations....
  12. Remstarasianboy
    Austin TX
    2013 Prius v wagon
    I am definitely. It second guessing the car. I use to have a 2007 Honda Civic Hybrid and new the exact range of the vehicle.
    I was wondering exactly what the range of the Prius was because the light started to beep and I was only at 467 miles. The onboard was reading 51.2 and distance to empty was not right.
    Thanks for the help guys. That really helps me a lot.
    How about a stupid question now. Why the hell is the heated seats panel so far away???? I don't get it.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The problem with your assumption is that you assume you will get xxx more miles with xx gallons left in the tank despite your mpg being variable. Even if you average 50mpg over the course of the majority of the tank, you last 2gallons could be used while you're only getting 30mpg due to current conditions. Itis always best to just refuel at 1/4tank or when. The car alerts you to do so. Trying to second guess the car is just asking for trouble. :)
  14. dogfriend
    7,512
    1,191
    Carmichael, CA
    I think the 2010+ models may be more predicable in this regard, but just because you got 500 miles (or whatever) on the last tank, don't assume you will always get 500 miles. It don't work that way. :madgrin:
  15. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I've found 0 to go to mean between 9.5 and 9.8 gallons first click.
    I don't push it, but because of the buffer and the car's fuel economy I don't sweat DTE 0 and can wait for my next convenient opportunity.
  16. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Follow up: I found my receipt for the aforementioned fill up. TripA 600.1 miles, Cons. 55.8 MPG, my calculated MPG 52.56 MPG, fuel added 11.417 Gallons. Like I said probably won't be doing that again.
  17. bisco
    52,854
    go for 600. what's life without a little risk? you can try to push the envelope, but don't forget, it will always remain stationary.
  18. stevil
    stevil New Member
    Denver, Colorado
    In any other (non-Prius), two things would be true:
    1) I'd be driving it like a normal car, unaware of, and therefore not doing too much to maximize my MPG - this is usually going to translate a calculated average that includes a lot of non-optimal driving (closer to worst case mileage than best).
    2) I'd have an analog gas gauge instead of a blinking meter segment, and over time would learn what "less than E" really meant for that car and my driving habits.
    As a result, I'd be comfortable driving it past E, and well past the car's early fuel warning light.
    In the Prius, I get nothing but that blinking meter segment on the gauge and the early warning. I don't feel as comfortable running past the warning, because a cold spell, or a different route, or having someone else in the family drive, could push me too close to the edge, and I'd never know it.
    My choice is to get to my favorite local gas station as soon as reasonably possible when I see the meter start to blink.
    This time, I drove about 5 miles to the station, and put in exactly 10 gallons (about .4 gallons after the twitchy pump shut off). This was my first tank, so I've no idea mow much fuel was REALLY in the car, and when it was topped off.
    If they topped it off before delivery, I got 44mpg calculated in Denver - not bad for winter, a little snow, E10, and brand new tires!
  19. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    The better gas mileage of a Prius translates to more uncertainty of remaining range. As an example, let's say mileage varies by 20% depending on external factors, and that 2 gallons of gas remain when the low warning light goes off. Now let's apply that to a high mileage car like a Prius and a low mileage vehicle like a Jeep:
    Your Jeep's good mileage is 18 mpg, which means at 20% down it's 14.4 mpg. The difference is 3.6 miles. Given two gallons of remaining gas, on a good day you can drive 7.2 miles before running out of gas.
    Now for the Prius. On a good day you get 55 mpg. On a bad day 20% less, or 44 mpg. The difference is 11 miles, so with two remaining gallons of gas you can drive 22 miles on a good day. With the Prius you have more than twice the uncertainty of the distance to empty.
    This range uncertainty is multiplied by the fact that the Prius is probably more sensitive to external factors. Your gas guzzler guzzles no matter what, but your Prius excels only when all the factors are just right.
    Tom
  20. kornkob
    kornkob New Member
    128
    Wisconsin
    I'm with you there. I'ts been years since I drove a car that I wasn't willing to put gas in when I reached half a tank. There's no value in running a tank to empty before refilling and it only takes 2-3 minutes to fill up now that you can pay at the pump virtually every where.
