prius not always start unless key on off few times
Discussion in 'Generation 1 Prius Discussion' started by boostedsil40, Nov 7, 2018.
  1. boostedsil40
    boostedsil40 Junior Member
    24
    AZ
    2002 Prius
    We got a prius from family and it has this issue where some days you have to turn ignition on/off from a few times or sometimes when it doesn't start I wait a minute and it starts?The thing is the car does this often yet never has it left me stranded as it seems sooner or later from ignition on/off/on etc it will eventually start.I got a brand new 12v battery from dealer but didn't fix it,I make sure brakes pressed nice and firm but it randomly acts up.Im sure many have had this same issue what should be checked?
    52,857
    maybe loose wires in the switch?
  3. pshawfocus
    pshawfocus Picard would own a Prius...
    44
    London, UK
    2001 Prius
    I know many conventional cars require the brake to be pressed before the engine will start but you don't need to touch the brake pedal when you're starting a gen 1 (or any of the later Prius / HSD Toyotas from memory). Happy to be corrected if I'm missing something but I always just get in, turn the key and go.
  4. boostedsil40
    24
    AZ
    2002 Prius
    ignition switch?Maybe a voltage drop test is in order.
  5. boostedsil40
    24
    AZ
    2002 Prius
    Ill try starting while not pressing brake to confirm,Thanks.
  6. boostedsil40
    24
    AZ
    2002 Prius
    I didn't do a voltage drop test because ive been at work so I can mess with car this weekend,i found a new ignition switch for $10 online so I pulled the trigger even though I didn't vd test the switch but for so cheap if it don't work oh well.I read something about throttle plate creating a no crank is this correct?if so how do I test and what other suspects are there?
