Prius not used for two weeks or more
Discussion in 'Gen 3 Prius Technical Discussion' started by bulajap, Sep 29, 2012.
  1. bulajap
    bulajap Junior Member
    Niagara Flls
    Hi everyone...
    I have a new 2012 Prius ( model 4). When I was reading the manualregarding the smartkey it stated that if the car is left unattended for 14 days or more, in order to not put a drain on the 12 volt battery, you cannot open the other doors when you approach with the smart key. It states to either try opening the driver's door with the smartkey, or use the manual key.
    How would you get the function of of smartkey back?
    thanks
  2. gliderman
    gliderman Active Member
    751
    223
    Open the door with the manual key and start the car and recharge the 12v battery. If the 12v battery isnt too far gone.
