Prius or 2025 Camry?
Discussion in 'Gen 5 Prius Main Forum' started by Johhhn, Dec 6, 2024.
  1. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    The 2020 and earlier-model-year Prius Primes had TSS-P (as in 1.0). My 2021 has TSS 2.0.
    Moderate as in typical freeway curves? TSS 3.0 also has adaptive curve-speed control, which TSS 2.0 didn’t; so, it is strange that it wouldn't handle the moderate curves well. I don’t think mine has any issue at typical curves a driver can do 65 mph at without much attention, but it wouldn't work at a sharper ramp or or any curve that is challenging for the driver as well.
  2. Prodigyplace
    12,712
    11,848
    Central Virginia
    These were 45 mph curves. Highway 24 between Highway 29 & Highway 501.
    Google Maps
    Gokhan likes this.
  3. Gokhan
    6,714
    2,672
    Paramount CA
    Ha ha, no, I wouldn’t call a 45-mph curve a moderate curve! That is a curve that would end you up off the road even if you blinked for a fraction of a second. I wouldn't trust TSS 2.0 or 3.0 at any curve with a yellow speed warning. 65-mph (or perhaps 55-mph) curves without a yellow speed warning are OK.
    How well does the adaptive curve-speed control work in TSS 3.0?
  4. ETC(SS)
    7,555
    If you're over 18 (or have a three digit IQ?)
    Camry.
    It's not even close.
    Prodigyplace likes this.
  5. Prodigyplace
    12,712
    11,848
    Central Virginia
    It is quite subtle and I have not particularly noticed it. I turned off the proactive braking assist because it would brake too quickly for my linong when there was a car in front of me. i prefer braking gently to regenerate more power.
    Gokhan likes this.
  6. Hammersmith
    Hammersmith Senior Member
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Unless you need a hatchback. Then it's not even close the other direction.
  7. ETC(SS)
    7,555
    Excellent point!
    However (comma!) if you need a hatchback I would submit that there are others that are better at doing 'that.'
    If you HAVE to get EITHER a Camry or a G5 Prius?
    Yeah.
    The G5 has a hatch, and if you "need" one of those - the G5 Prius is a good (if expensive) option.
    Best,
  8. Prodigyplace
    12,712
    11,848
    Central Virginia
    In my case we decided we did NOT want a hatchback thi time. We have a 2000 Tundra pickup truck for the large stuff.
  9. Gokhan
    6,714
    2,672
    Paramount CA
    2025 Camry SE HEV emergency-handling maximum avoidance-maneuver maximum speed (CR): 53 mph
    2025 Prius XSE PHEV emergency-handling maximum avoidance-maneuver maximum speed (CR): 57 mph
    So, it is black and white: Camry HEV is a grandpa/grandma car in terms of handling in comparison to Prius PHEV.
    And Camry HEV has no plug.
    Prius PHEV is the clear winner here unless you are looking for a larger but slow-handling car and don’t care about BEV driving.
    #29 Gokhan, Dec 20, 2024
  10. Prodigyplace
    12,712
    11,848
    Central Virginia
    Why pick the Camry SE? The XSE is supposed to have the best sporty handling. I like the ride comfort of my XLE though.
    Gokhan likes this.
  11. Gokhan
    6,714
    2,672
    Paramount CA
    CR tested the SE.
  12. Prodigyplace
    12,712
    11,848
    Central Virginia
    To compare apples to apples, why didn't you compare the Prius to the Camry? That are both HEVs. You chose the PHEV so you could tout ist "advantage" of having plugin EV capability, something the Camry never claimed to have.
  13. Gokhan
    6,714
    2,672
    Paramount CA
    No, it would have been even more apples and oranges because CR tested Prius XLE AWD HEV. AWD changes the emergency-handling dynamics. It apparently made it worse, Prius XLE AWD HEV having scored 54 mph vs. Prius XSE PHEV having scored 57 mph.
    For me, I would not downgrade to an HEV anyway—either a PHEV or a BEV from this point on.
    #33 Gokhan, Dec 20, 2024
  14. mva
    mva Active Member
    177
    105
    B.C. Canada
    2024 Prius Prime
    SE
    Prius Prime is 220 hp combined and 6.5 seconds 0 to 60 mph per Car and Driver versus
    Prius Hybrid is 194 hp combined and 7.1 seconds 0 to 60
    I couldn’t find info on the Prius AWD but probably a bit slower than the fwd.
    Camry Hybrid AWD is in a similar range at 6.8 seconds to 60 mph.
  15. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    I'm wondering the same. We have a '17 Prime Advanced with 352k miles and an '07 Prius with 520k miles. The '07 needs some work (we just put a bunch of money into it) so I think it's done. So, we might need two new commuter cars soon. My husband has been driving my '16 WRX for the past while, and it's now at 80k (started at 30k before he used it to commute) and I can't see it handling this kind of use that much longer.
    I drive 50k/yr and my husband drives 25k/yr. I'm going to buy either a Prius Prime SE, Camry XSE, '22 Avalon Limited or a Lexus ES300h luxury. That's what I've narrowed it down to.
    We have rented a base Prius for the week. I don't like the inside of the new Prius. It feels claustrophobic to me. I'm not a big person and I own two seater sports cars (Corvettes/Porsche) so I'm used to cars with less interior space. My husband isn't bothered by it. I'm going to trade in the rental Prius for a '25 Camry LE and see what that is like. If I don't like either, I'll go with the Lexus (which is just a Camry, anyway) if I'm using to commute. If my husband commutes with it, we will go Prius Prime.
    I carry a spare in the '17 Prime and have gotten a flat three times in the past five years. The new Prime has even less space, so I don't know how this would work. The camry comes with a spare. The Prime or even base Prius gets much better gas mileage.
    For a second commuter car, it will be another Tesla. We already have a '22 Model Y Performance. I don't commute with it. I'm considering getting either a low mileage used MYP or a model 3 performance and just driving it for 50k/yr and seeing what happens. The Tesla brings joy to my life that the Toyota doesn't. If you don't drive an insane amount and the 120k mile/8 years makes sense, I would recommend test driving a Tesla Model 3 or Y also.
    Note- those of you buying, after much running around, I can get a Prius Prime SE for 32.5k or a Camry SE with the cold weather and convenience package for 32k. I can't find lower. They don't seem to be negotiating a whole lot, even in December.
    #35 JMalmsteen, Dec 25, 2024
    Gokhan likes this.
  16. Prodigyplace
    12,712
    11,848
    Central Virginia
    The Lexus ES300h Luxury appears to be between the Camry LE & XLE. The Camsy XSE equivalent would be the Lexus ES300h F Sport Handling. If the versions compare, the Lexus only has the Safety 2.0 vs the STAR 3.0 on the Camry. I would try to drive a Camry XLE before buying the Lexus. many have compared the new Camry to the Lexus, but for much less money. I test drove a Camry SE before buying my XLE a month ago and the ride is much better on my XLE. Adding the Premium Plus package to the XLE gives the ultimate safety features from Toyota. I am really pleased with my choice.
    Gokhan likes this.
  17. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Once you get 50 MPG, there's no going back.
  18. Gokhan
    6,714
    2,672
    Paramount CA
    Yeah, if it hasn’t been upgraded to the Toyota/Lexus safety system 3.0 yet, don’t buy it. That is because that is the most important feature of a car by far.
  19. Prodigyplace
    12,712
    11,848
    Central Virginia
    Actually, I DID go back from my 2017 Prius Two that got a lifetime55.4 mpg of mainly highway driving before it was wrecked. So far. with winter fuel learning to drive my Camry XLE, I try to get over 44 mpg. It is much heavier and a smoother ride which is worth the tradeoff for me as I get older.
    Gokhan likes this.
  20. Gokhan
    6,714
    2,672
    Paramount CA
    Well, I average 70 mpg on mine if not more; so, 50 mpg is a nightmare for me.
