Prius overheating on highway. Changed thermostat. Water pump is operational.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by CAITLIN FOLEY, Apr 28, 2020.
  1. CAITLIN FOLEY
    CAITLIN FOLEY New Member
    Memphis, TN
    OK, the thermostat opens up in the boiling water on stove. Thermostat good. I am curious about this idea of the water pump being only half power. This might explain issue. When I get the thermostat open by running engine, the hose water sucks right up into the block. So the only difference I can think between the hose water, which goes all the way thru engine and radiator, and the water coming out of radiator is different pressure. I guess the water pump isnt pushing the water with enough pressure to move the emmissions , heater core , etc,. but not ebough flow to push it through the radiator as well. But even when I pinch the alternate thermostat hose input that sets the open/close temp, the system still doesn't pull water through the radiator. So weird. I guess I'll dismantle the water pump and check it for full functionality.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    OK.....well that is REALLY unusual to have the thermostat mounted near the BOTTOM of the engine.
  3. sam spade 2
    7,035
    2,803
    2017 Prius c
    Please keep us posted with your progress.
  4. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    Traditional thermostats can be checked via the hot pot of water and a thermometer method.
    :coffee:
  5. Mendel Leisk
    41,479
    What I found revealing, was to suspend both the old and replacement thermostats in a pot of water, bring it close to boil while watching their relative performance.
    fuzzy1 likes this.
  6. ChapmanF
    18,224
    Right at the water pump inlet. Same place it was in the 1NZ, only that was a separate traditional looking thermostat sitting behind the elbow, instead of built in to the elbow.
  7. fuzzy1
    10,463
    I'm not required to have a dog in that fight. Spectating is just fine.
    #27 fuzzy1, May 2, 2020
  8. Mendel Leisk
    41,479
    Deleted, inflammatory.
    #28 Mendel Leisk, May 2, 2020
    Tim Jones likes this.
  9. sam spade 2
    7,035
    2,803
    2017 Prius c
    And apparently you think throwing insults at others is perfectly fine too.
    Even though you are "not required to have a dog in that fight" either.
    :p
  10. fuzzy1
    10,463
    I didn't know that was your exclusive territory.
  11. fuzzy1
    10,463
    Changed it back to standard form.
    Tim Jones and Mendel Leisk like this.
  12. Mendel Leisk
    41,479
    Sorry for my previous post, it was inflammatory.
    Tim Jones and fuzzy1 like this.
  13. fuzzy1
    10,463
    Probably no more so than mine, also backed out.
    That part you were curious about, can be edited to read whatever you want.
  14. CAITLIN FOLEY
    Memphis, TN
    UPDATE:
    Per Sam Spade's suggestion, I pulled the water pump. I had seen a video of a water pump replacement where the mechanic shows a good pump next to a bad pump. He shows how the spindle spins freely on the good one and has resistance on the bad one. Then he takes the spindle out and shows the magnet bulging out on the bad one. So I try mine out. It spins, but not freely like his good one. I take out the spindle. It's bulging out and magnet coating beginning to tear showing a tiny bit of rust.
    I believe I found my problem! If it's not the cause of the overheating, it needs replacing anyway. But it's definitely not pushing at 100%. I'd guesstimate the resistance I could feel manually would reduce the power 20% to 50%.
    Ordering pump tonight. I'll update after replacement.
    Thanks guys!
  15. Air_Boss
    Air_Boss Senior Member
    4,200
    1,184
    New Yawk
    Aha. So that's an induction motor.
  16. ChapmanF
    18,224
    Pretty sure it's a permanent-magnet motor. A bunch of motors in the car are. Maybe I'm mistaken....
  17. CAITLIN FOLEY
    Memphis, TN
    Pretty cool contraption. Evidently the impeller just sort of floats in midair while spinning.
  18. Air_Boss
    4,200
    1,184
    New Yawk
    Magnetic bearing, in all likelihood.
  19. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,467
    2,434
    Taylors, SC
    A magnetic link, not a bearing, is very commonly used in chemical bath stirrers. There is no physical seal that is prone to wear and leaks.
    Air_Boss likes this.
  20. ttou68
    ttou68 Active Member
    351
    211
    I just replaced one, and too bad there's no rebuilt kit for it...
    And in similar situation, lower radiator hose doesn't seem to get as warm as other hoses. Even though engine never got above 199° after 70~80 miles of very hilly highway driving, still thinking about replacing thermostat at the moment..
    #40 ttou68, May 8, 2020
