Prius, overheating P1150. Coolant loss. Replaced Everything
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BillS., Jun 24, 2016.
  1. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I think spending major money to repair an engine with 240k miles is a bad idea.
  2. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    You could try adding some oil stop leak solution to your oil or head gasket stop leak to the radiator fluid. These solutions seep into the engine seals and cause them to swell, which can help stop leaks and improve cylinder compression in the short term. Such solutions rarely work in the long term however; it might work and you squeeze another 20-30k out of the engine or more before the problem reappears, it might do nothing, or in some cases people have found it to make leaks worse. It's a cheap gamble however for just the cost of a bottle or two. I've personally never used any of these products, just read about them. The right way is of course to replace the appropriate gasket.
    If I was to continue to drive it, I'd get a water temperature sensor like a Scanguage so I could monitor the water temperature and drive around with radiator fluid and distilled water in my trunk in case they're needed. Other option is to sell it. I think I'd take ~$2k off bluebook and see what offers you get. You might be surprised what you can fetch for it. The battery and transaxle alone are worth close to $1500.
    In any case 240k is a great run for an engine. We're just spoiled in the Prius world where 300k+ is not a rare occurrence.
    #22 Kevin_Denver, Jul 18, 2016
  3. BillS.
    BillS. New Member
    16
    Wisconsin
    What do you guys think about an engine swap? I'd be willing to try it, from what I've read it doesn't sound too bad. There's one for sale a couple blocks from me for $395, with 84k. It's a 2005, but that shouldn't be a problem going in an 06 right?
    52,844
    sounds like a great idea.(y)
  5. imlkrsfn2
    imlkrsfn2 Junior Member
    23
    Stockton, CA
    I would definitely do an engine swap rather than trying to replace the head gasket on a car with 240k miles. $395 for an engine is nothing. If you want an engine with fewer miles, try looking for a used engine from Japan. They have high taxes on their old cars and they get rid of them early, sometimes with as little as 20-30k miles.
    MTL_hihy likes this.
  6. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Used JDM engines are definitely the best way to go when swapping foreign motors because they are usually well taken care of with very low miles. The swap should be quite simple and worth the money if you plan on driving the car for a long time. Be wary of super deals on low mileage local engines unless you can hear it running or test the compression on them. Also check inside the valve cover for signs of sludge or buildup indicating a lack of maintenance during use.
    m.wynn likes this.
  7. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    I would get the $395 engine and put it in. This is what I plan on doing if mine blows. Any idea on what caused a blown head gasket or was it just a freak thing?
  8. gamma742
    gamma742 Member
    178
    73
    Luxury
    Do you mind if I ask.. Has your HV Battery been replaced or is it the original?
  9. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    Mine is original 2005 225k miles. I've seen used original Prius batteries out of wrecked lower miles cars for $850 installed which is the way I think I'll go if it goes bad.
    Where is the best place to buy these JDM engines?
  10. BillS.
    BillS. New Member
    16
    Wisconsin
    Update: I bought a bottle of BlueDevil over the weekend. I pulled out the thermostat, flushed entire system and added the sealant. Ran it in inspection mode for 50 minutes and then reinstalled the thermostat. I am now going on 6 days with no overheating or coolant loss. Previously it would only take about a day and a half for this problem to occur. Things are looking good for now, but I think I need to get out on the highway for a while and put some serious miles on.
  11. BillS.
    BillS. New Member
    16
    Wisconsin
    Spoke too soon. Light came back on this morning, and no heat.
  12. Patrick Wong
    18,210
    6,517
    After you reinstalled the thermostat, what was your process to purge air out of the system?
    During that process, did you have the cabin heater on, MAX HEAT setting, fastest fan speed?
    Did you rev up the engine repeatedly to push air through the system?
    Was the cabin heater working satisfactorily at the end of this process, without any sound of air bubbling in the heater core?
    Did you check the coolant level in the radiator each morning after performing this process, to top off the engine coolant level? This must be done until the level no longer drops.
    SPURPURA likes this.
  13. BillS.
    BillS. New Member
    16
    Wisconsin
    Hi Patrick! Thanks for your response. After thermo reinstall I topped it off, ran engine, squeezed hoses while adding more coolant and opened bleeder valve a few times. I had the heat on max while doing this, but did not rev the engine. The heat was not working sufficiently when I finished, and I could hear some bubbling. After a couple days of driving the heat started working again and the bubbling stopped. I did top it off a couple times the first day or two, but I had stopped doing this the last 3 or 4.
    I will take your advice and top it off again, heat on max and rev the engine while doing so.
  14. Patrick Wong
    18,210
    6,517
    Bill, do not be afraid to rev the engine. When the gear selector is in P the engine will only rev up to 3,000 RPM or so. If you hear air bubbling around then you must continue the process.
  15. BillS.
    BillS. New Member
    16
    Wisconsin
    Hi Patrick. I did what you recommended. Put in inspection mode with max heat and spent about 30min adding coolant, revving engine, squeezing hoses and opening bleeder valve. I did this until I absolutely could not add any more. The heat started working as I was doing this and now the heat works all the time. Thanks for your help!
  16. BillS.
    BillS. New Member
    16
    Wisconsin
    Going on two weeks now with flawless heat, no coolant loss and no warning lights. I just drove it from Milwaukee to Chicago and back on Saturday averaging about 75mph.
    Now, the conundrum I am having is do I sell it as a regular working Prius with 240k? I want to keep the car really bad, especially after all I've done to it, but I'm worried this fix will only get me another year out of the car.
    SPURPURA and bisco like this.
  17. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    If you like the car, drive it til the wheels fall off and buy some more wheels. Seriously, if these cars are maintained they will last a long time. My 05 was pegged out at 300k for who knows how long when the water pump seized up, broke the belt, and overheated the engine. Lack of maintenance from the previous owner. I bought it like that and swapped the motor/trans., the subframe, and the interior from one with 85k on it. Hope it lasts another 300k, it's paid for!
    bisco and m.wynn like this.
  18. Nate Berry
    Nate Berry New Member
    North Carolina
    Hey Bill, I'm having the same issue. How did you finally figure out it was the head gasket?
    I've also had several technicians look at my Prius and tell me my head gasket is perfectly fine.
  19. evallded
    evallded Junior Member
    71
    Portland, Or
    My apologies for necroposting but I wanted to put this back into circulation to try and get the end result if possible. I am having the exact issues mentioned here, replaced all the parts and am now considering doing a head swap
  20. siskilla
    siskilla New Member
    nj
    2008 with 87k miles...i hear the noise from the engine bay when i park, the heat blows cold...the triangle of death comes on for seconds at a time with the temp overheat symbol... the check engine came on for the p1121 coolant control valve but went off on its own... so the car runs for weeks at a time without issues, then when i add water/antifreeze, and satisfied bled, it starts overheating...should i change the control valve or is this a bad motor?
