Prius owner in tropical climate
Discussion in 'Gen 4 Prius Technical Discussion' started by Darko, Aug 14, 2023.
  1. Darko
    Darko New Member
    Singapore
    2018 Prius
    Hi. I am from Singapore, a country in the tropics. I have a few questions not sure if you guys can help me with?
    1) my mileage is 111K. My mechanic ask me to use high mileage oil or 5w30 oils. I realize the fuel consumption went up by quite abit. I am wondering is it necessary? Or should I just stick to 0w20? I have went back to using 0w20 for the last 18,000 miles. Will it damage my engine?
    2) they also recommend an engine flush. Do you think it's necessary? My car is daily driven even on weekends and I do my servicing every 10K km religiously.
    Thank you.
  2. Tideland Prius
    16,674
    Recommended engine oil will differ by region so it’s best to consult your owner’s manual for the recommended oil for use in Singapore. Typically, yes a thinner oil will improve fuel economy. 110,000km isn’t that high of a mileage. We were never asked to switch oil on our Gen 3 at 160,000km. I can’t remember if we did on our Gen 2 which lasted 245,000km. The gen 3 used 0W-20 and Gen 2 was 5W-20 IIRC. Over in North America, the Gen 4 uses 0W-16 but that’s because of our winters.
    If the manual suggests 0W-20 and you haven’t noticed any oil leaking or burning, you should be fine.
  3. Leadfoot J. McCoalroller
    8,275
    7,779
    Pennsylvania
    2018 Prius c
    No reason to stray from 0W-20. Enjoy the fuel savings.
    I don't think your mechanic gave you bad advice, but maybe stale advice, meant for older cars.
    I enjoyed my visit to Singapore last fall. From what I saw of people driving in the city, your car can last a very long time with the sort of service you describe.
    Darko and Tideland Prius like this.
  4. Darko
    Darko New Member
    Singapore
    2018 Prius
    Thank you Leadfoot and Tideland for your replies.
    Yeah Singapore is just city driving. We are that small. Max 90km/hr on highways.
    My Prius is a Japan Domestic Model. It's manual is all in Japanese. I Google translate parts of it and it say to use 0w16. No mention of any recommended use of high mileage oils. So far no problem with 0w20. No leak or burning of oil. Just needed some assurance on what I did is right.
    Btw I m running private hire like uber or lyft in Singapore so I have significantly higher mileage than other car owners. It's currently at 180k km. I thought you guys are more accustomed to miles. :)
    How about engine flush? Is it necessary?
    Tideland Prius likes this.
  5. bisco
    52,803
    welcome!
    engine flush = wallet flush
  6. sylvaing
    sylvaing Senior Member
    1,219
    516
  7. Tideland Prius
    16,674
    No engine flush needed.
  8. Darko
    Darko New Member
    Singapore
    2018 Prius
    Thank you guys for the replies. I feel so much more assured that I m doing the right thing for my Prius. :)
  9. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Just noticed the thread today. As long as the color of you coolant is light pink, you should be good. specially at only 111km. I got a gallon of Toyota Super long life coolant to top off my engines slightly lowish level showing in the reserve tank. I used about a cup of the gallon so far at around 137 km.
    singapore link to toyota super long life coolant, if I can get it to show up here ....
    https:// http://www.lazada.sg/ tag/ toyota-long-life-coolant/ -- remove the spaces in the link
    Here is a video I found when seaching out info for another post here a priuschat that gives an overview of how to do the coolant flush. It also shows how to replace the water pump if that is of interest to anyone.
    I was able to put my 2017 Prius Prime in maintenance mode using the instructions from this video. Thanks to @Peter123
    Aisin Water Pump Video with Coolant Bleed Instructions | PriusChat
    #9 vvillovv, Aug 17, 2023
    Darko likes this.
