Prius owners with Catalytic Converter protector! Help other Prius Owners find the right protector.
Discussion in 'Gen 2 Prius Main Forum' started by Kaptainkid1, Jan 25, 2021.
  1. khp
    khp Member
    76
    45
    SW Washington
    I was thinking about you testing for excessive heat because of lack of airflow and it got me thinking. I have a thermopro tp20 for my BBQ grill. It has two temp probes that pull into transmitter and you them read the temps on a receiver. I watch my grill and meat temps from the house. I am going to use this to check temps behind engine and around the cats before and after the install of my protective guard covering the cats. It would be interesting to see the temp change if any. This isn't the best time of year to test this because its cool now. I have a filr ir camera but I think the the Thermopro will work better. Test while driving around town.
  2. ETC(SS)
    7,157
    This is the advertisement that I got while reading this thread.....
    https://www.grainger.com/product/2RPC4
    Electric Pipe Cutter for Pipe 2-1/2 in to 8 in, 22 1/2 in Overall Length, Power Drive Required to Op
    RIDGID
    Uh.....
    Yeah.
    I guess it could have been worse.
    There are hand-held units that make zero noise....
  3. fleafrier1
    fleafrier1 Junior Member
    california
    I’m pretty sure the hand held one is what was used on mine
  4. ETC(SS)
    7,157
    You have to know your enemy.... ;)
  5. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    That reminded me that the O2 sensors also give temperature before and after the cat. The probes would be great to check other areas though.
    iPhone ?
  6. khp
    khp Member
    76
    45
    SW Washington
    This is what I did to my daughters Gen II. I made a cover that covered the bottom of the exhaust manifold that connects to the first cat. Also welded some wheel locking nuts to the flange bolts. So using a ratchet, extension, and 14 mm socket won't work to remove the bolts. The cover should discourage cutting the pipe after the flange like they did the first time. Then I welded two rods between the front flange and first cat, two rods between the two cats, two rods between the last cat and resonator. Then I made a cover out of 16 gauge sheet metal I had in my shop. I cut some vent slots in the cover to help dissipate heat from the cats and may cut in some more.
    I am going to do some temperature testing on this car with all this protection on it. I do have some concerns about these cat shields holding excessive heat in the cat area. I will test my gen II with no covers or cat plate and compare to the one with a cat cover. I bought a CCM cover for my gen II but have not installed it yet. I think all this should slow any cat thieves down a bit.
    fleafrier1 and Kaptainkid1 like this.
  7. khp
    khp Member
    76
    45
    SW Washington
    Cover over exhaust manifold flange. Open on top.
    Kaptainkid1 likes this.
  8. ETC(SS)
    7,157
  9. Kaptainkid1
    Kaptainkid1 Active Member
    308
    247
    Los Angeles
    I took my Prius last year to a California Star Smog Center and the technician saw my Prius has a grate mounted under the car as protection. He was a little annoyed but he did pass my Prius for approval. He said during visuals inspection he was able to read the California compliant stamp but would have been a violation. Also my grate is screwed on so it can be taken off and put back no problem. 20191215_133312.jpg 20191215_133322.jpg 20181212_145756.jpg
    SM-J737T1 ?
    #29 Kaptainkid1, Feb 13, 2021
    Georgina Rudkus likes this.
  10. khp
    khp Member
    76
    45
    SW Washington
    If I had to do it again I would use expanded metal. That and weld rod at the cut points and protect the front flange area. Heat dissipation would be better in the summer. I did some temp testing while driving around (air temp outside was only about 60 deg) . The only time the temp climbed up over 100 deg at the front cat area is when I drove a few miles down the the freeway and stopped at a light at the exit ramp. I cut some extra vent holes in the rear of my cover. Driving around town stop and go didn't rally climb that much. If there is a little air flow the temp stayed way down. Those heat shields are very important.
  11. ETC(SS)
    7,157
    Hope you don't 'have to' do it again....
  12. fleafrier1
    california
    Kind of a bump on this thread. I finally put some holes in the small shield I made to get in the way of my front flange bolts. I was able to use a punch for all of the ones above the bottom row which saved some time. I'm lucky I have access to equipment that can do that. But I think I agree with you that the expanded metal seems like a good solution. For a reasonably skilled DIY owner it's probably as good a guard as an aluminum cat shield.
    Kaptainkid1 and Sanchan like this.
  13. rep308
    rep308 Junior Member
    71
    suburbs of Boston
    Miller Cat guard ($180) being installed for $150 next week
    Raytheeagle likes this.
  14. rep308
    71
    suburbs of Boston
    The local shop only charged me $50 to install, this is a no brainer. They can get the cat even with this on, but I'm hoping they will just skip me and find another Prius
  15. rm04
    rm04 Member
    53
    27
    United States
    I just had a Miller Cat Shield installed with the upgraded hardware. To me it makes the most sense because as far as I know the other major brand uses rivets that are a pain to remove while the Miller uses security screws that come with a special bit so the plate can be easily removed and reattached
    As far as I know Id go with the Miller with the upgraded hardware
